BettyWhite
Fixed
Though, I wasn't feeling too confident about cutting the section of wire out, I took the car to a local shop. The mechanic added in the new section of wire, I hit the AC button and now my AC works! My pocket is $50 lighter for his labor, but I'm glad the job is done.
Thanks for the help Dan and everyone
Pierced the wire with the connector hooked up and the voltage read around 1.12 volts. T14/Pin 4 it is.Your immediate problem is a lack of power on T14/4.
Check the wire by piercing it, to see if it has voltage.
The most common fail point, after the fuse, is the electrical joint right at or inside the T14.
If that is the problem, you can buy a repair wire at VW and replace that section of wire and the connector.
