christi
I am no expert on oil.
I use a fully synthetic diesel specific oil made by Miller Oils in the UK. I am sure it is way in excess of what the engine needs, but I tend to run my cars till they die, and the longer that takes, the better, so I by the best that I can get.
I have no idea either how blocked the inlet manifold is. On the 806 it is totally impossible to see it. However the pipe from the EGR valve to the inlet manifold was totally clear when I removed it at 130,000 miles. Now I have no EGR valve at all, just a couple of blanking plates. Mine is the 8v engine though with no EGR cooling.
I had a lot of hassle and expense at 130,000 with injectors though. One of them at least was causing a heavy rattling noise whenever I demanded power, and the reconditioned set that I bought didn't last long. Injectors for common rail diesels are expensive and complicated.
I would say that one of the most important things with these vehicles is to be very, very careful with fuel quality.
Water in the fuel will kill them, and if you ever accidently put petrol in then do not even turn the key, as this fires up the tank pump and pushes petrol around much of the system.
If you lend the vehicle to someone then better that you give it to them with a full tank of fuel...
If you can find a fuel additive that increases lubricity of the fuel then use it. I am talking about additives where you add a small dose at every fill up, not one shot cleaning additives.
If I look at cost of ownership over the last year and factor in cost of new injectors (twice) I would have been better off with the 2.0 petrol. I now need some good reliability for a few years to get my money back. My 806 has 155,000 miles now so how likely is that...
