Check engine light reset
oldschoolboy
Charlotte, NC
2003 Jetta TDI 5-Speed
I had a bad glow plug. I replaced the glow plug but auto zone won't reset the check engine light. They said it would reset after a few miles. I have driven 500 miles and its still on. Can I buy a cheap obd2 scanner and reset it or should I just wait?
Vince Waldon
Edmonton AB Canada
A glowplug code almost for sure will not reset by itself (have seen a couple of scattered reports but they are very rare) but yes any OBD-2 scanner should be able to reset it.
Some codes will self-reset... but the glow plug code does not generally appear to be one of them for some reason.
RUGsux72
Richmond, VA
2012 Jetta TDI w/DSG & 2013 Beetle Convertible TDI w/DSG
Save your $...undo your wire from battery terminals BOTH + and - from the battery and cross the wires together...5 mins should do it...this resets the ecu :)
