Check engine light issues
RANGER26
Redding, CA
2005 JETTA WAGON
dealer said my 05 jetta tdi wagon had a failed mass air flow sensor so I replaced and cleared the check engine light. They also said to replace the egr pipe which I ordered but haven't replaced yet. Any thoughts as to the egr pipe and check engine light or issues related to the egr pipe in general. Thanks
Tankthecarman
United States
2001 Jetta ALH TDI 5spd
Have you entertained the idea of EGR delete? I did a simple EGR block off, but have not gotten a ECU reflash to eliminate the CEL.
VWfan2020
Las Vegas, NV
2013 VW Golf TDI
issues with tampering with EGR valve:
1) Will automatically fail a smog test upon inspection (that is if you don't put it back before testing)
2) May cause your engine to run hotter than normal ( leads to possible knock)
3) Possible damage to catalytic converter
