I have the same code going right now with my '00 Jetta TDI. I haven't had time to look into it. This is the longest I have ever let the CEL stay on. I double check ever few days with my ScanGauge to make sure there is not another code.Did an ops check today, found 1 of the glow plugs to be bad (12+ ohms)...reset the battery and still have the check engine light! Then I did a voltage check on the harness itself, all were around 11.5 volts when the ignition was on (w/ in 20 seconds). Any thoughts as to why I still have a P0380 code or is it maybe a coolant temp. sensor?
A basic code reader/scanner WILL normally clear the CEL, but unless the issue is corrected the CEL will return upon restarting. Most generic readers will display the numeric trouble code, but give no description of it.Your basic scanner will not clear the CEL, but many CEL's will clear after the problem is corrected and the car has been driven enough cycles. (fully warming up and cooling down).
According to Bentley you either have a bad instrument cluster or a Faulty coolant temperature sensor. Replace the CTS and your guage should work again.The last time I had my check engine light checked out, it was a glow plug issue (which I am currently diagnosing)...does this have any connection to my faulty coolant temperature guage not working at all on my dash while driving?
