Cheap DMF should I get?
CanadianALH
Canada
2002 Jetta 5spd 2006 Jetta DSG (wifes)
There is a local guy selling a LUK-4150250110 for like $250. Car is a 2006 BRM DSG. Mine is starting to make noise and I will replace it eventually. For that cheap I should probably pick it up. What else would I need for the change and my research shows it’s the correct one is that correct?
Rx7145
Ohio
2006 Jetta BRM
It does look like that should work, if it’s brand new that’s definitely a really good price.
Rx7145
Ohio
2006 Jetta BRM
You would need to buy new flywheel bolts other than that shouldn’t HAVE to change anything.
CanadianALH
Canada
Yes. It’s new in box and has the bolts. He was going to instal it and then hit a deer or a tree or something
MrCypherr
Ontario
Mk6 Wagon
I bought mine for $400 off Rockauto compared to other places that had it listed for almost double, let alone VW pricing at $1300 roughly. Seems like a good deal if it comes with everything.
CanadianALH
Canada
Yes. I just can’t find that much info on the kit. I think that part number is right. But FC euro is the only one I can find it on. ID parts and rock show nothing for that number.
CanadianALH
Canada
From what I can see it looks like the correct thing. I asked the guy for the part number again. As he was away and that was a SKU number.
MrCypherr
Ontario
Mk6 Wagon
Doing a cross reference check with that number, it seems like the OE part number is 03L105266E , Which checking that number with a couple of searches looks like its for a 5speed transmission BRM. Just checking from FCP Euro under the fitment guide.
CanadianALH
Canada
If you're searching rockauto, heres what I found for your BRM DSG;
Thank you for this! He is out of town right now. He is going to send me the number on the box tomorrow. Then I’ll know for sure. The DSG is such a weird animal and not too many places or people know what to do with it. Had a shop quote me $1900 to do the DMF parts and labour. They also bill $600 to do the fluid change. Needless to say I got Ross tech so when the day comes I’ll be doing it myself.
MrCypherr
Ontario
Mk6 Wagon
Its actually quite quicker to do a DSG I find. We quote $1050 labour including the labour for fluid change NOT including parts. Is that $600 on top of the $1900 or included? I'd double check that part number just to make sure because the flywheels are different as they call it a "wet clutch flywheel".
CanadianALH
Canada
The $600 was on top of the $1900 so to get it changed and have the fluid done it was like $2500 lol. I think labour for just the clutch was about at grand. VW shops around here are crazy expensive
CanadianALH
Canada
Yeah that does seem on the high end. Depending what their door rate is as well.
If we lived in the same province I’d just bring it to you. I’ll probably just pay a shop to instal it when it gets worse. Car isn’t driven nearly as much as my ALH so it will be fine for now.
MrCypherr
Ontario
Mk6 Wagon
Youll hear it get worse over time and you can use that as a gauge of how bad it really is. I've let mine go pretty long and it got to the point to where my release bearing was causing issues. This would have been around 20,000km.
CanadianALH
Canada
It won’t do it in any gear put park so I’m told that is a good sign. I’ll wait till it starts making noise in other gears. I just though the clutch was so darn cheap why not have it on hand.
MrCypherr
Ontario
Mk6 Wagon
Yeah usually youll only hear it in Park. Youll notice it get even worse when at idle the car feels like its misfiring.
CanadianALH
Canada
Part number is DMF072 for manuals. I need the 092. Oh well. Does any one need one for a manual?
BXE
Cornwall
VW Passat B6 1.9tdi
I changed the dmf and clutch on my wife’s mk5 golf manual I got a sachs dmf and clutch kit with 2 litres of gearbox oil in uk motor factors for £300 then spent about 6 hours fitting it myself.
but my local garage quoted me £1100 to supply and fit.
Glad I did it myself.
BXE
Cornwall
VW Passat B6 1.9tdi
Plenty of YouTube videos on how to andwithso e help from a friend much is possible these days.
