DidJettarun
Worked on a car today with only 4 lugs..could not get bolt to start...I need to chase threads...what is the correct thread pitch?
mk4's have 5 lugs.Are you missing a 5th lug, or does the car come equipped with four lugs? That could make a difference in size.
Where I bought my tires, the tech applied the torque wrench after the impact wrench. So naturally the torque wrench will click at 90 when the true, over applied torque is more like 130 foot pounds.
Yeah, it's pretty much what you have to expect though from an auto repair shop. I had to have the shop work on mine in December (accident repair...ins was paying). They replaced a front wheel. I snapped a 3/8" extension and split a socket trying to loosen the lug bolts afterwards when I went to make sure they were properly torqued.I cringe when I see this...
Chased both the lug bolts and the threads in the hub. The lug bolts thread in so so much better now!Might help or might take off some coatings and make them rust worse in the future.
You can get aftermarket lugs for like 2 bucks a piece.
I am torn I have read a lot that said the threads need to be clean and dry to reach their proper torque.Put some copper anti-seize on the threads.
Correct. However, you can still achieve proper torque by following the directions from whatever anti-seize you use to compensate for the change exacted by the anti-seize.I am torn I have read a lot that said the threads need to be clean and dry to reach their proper torque.
Interesting, I just read the PDF instructions for Permatex and nothing is mentioned. Who else makes anti seize?Correct. However, you can still achieve proper torque by following the directions from whatever anti-seize you use to compensate for the change exacted by the anti-seize.
Qualifier, I have never used anti-seize on my lug bolts. I simply wipe my lug bolts clean, blow out any dust from the hub, and torque to spec with a torque wrench in the recommended star pattern. I actually torque in two steps - half spec with wheels just making contact with ground, then full spec under full weight of the car.
Loctite also makes it. They do provide a formula for figuring out how to de-rate the torque when using their product but it seems confusing to me.... Who else makes anti seize?...
