Johnny Cetane
- Joined
- Jan 5, 2002
- Location
- San Luis Obispo, CA
Does anybody know how to change the injection timing slightly? Any information at all would be greatly appreciated.
Thanks,
John
Thanks,
John
<font size="2" face="Verdana, Helvetica, sans-serif">I respectfully disagree 100% with the above remarks that are not truthful on the date posted. The learning curve has steepened considerably the last few months in the education and experience department, including knowing what factors alter the combustion process and what symptoms are good indicators of this.Originally posted by Drivbiwire:
YOU specifically have NO IDEA what your doing much less what some of these funtions even do. All you know is that it makes changes but you have no idea how they change or modify other factors of combustion in a CI engine.
DB
<font size="2" face="Verdana, Helvetica, sans-serif">Just imagine how much further along the learning curve we will come when TS is forced to transition to his 3rd engine?Originally posted by Turbo Steve:
<font size="2" face="Verdana, Helvetica, sans-serif">Ted, we do it on a MAP based on RPM and load. When you do it with the vag-com you are doing it across the board.Originally posted by Ted_Grozier:
15 bar per each two degrees is a linear approximation...
I agree that timing advance is dangerous. But why does anyone think so badly of 2 degrees advance when that's what you get with UPsolute??
