Changing gearbox
zzdiesel
sask. mostly now Wa.
05 passat tdi Geared BSM and Bewcam 2nd 2005 deleted ,converted and bew cam stage 2 Malone3 tune.
So, having problems with my FHN gearbox, long story, changing to an EEN tranny. What problems will I be facing? Will the ECM need to be recoded due to the differant gear ratios? It has a Malone tune. Also what pilot bearing are people using?
caffeine
B.C., Canada
03 Allroad w/04 BHW/02X conversion, 00 ALH Jetta
The B7 2.0T pilot bearing is a good choice for a BHW as it's longer than the B5 1.8T one.
CantWrite
Placerville CO
2005 Passat Wagon (BHW/5-spd conv, 03T). I keep in touch with the (2) ALH's I sold.
Cant help at all, but I bought mine EEN swapped and I see 2800 rpm at around 80 mph with stock size tires.
good luck with the swap
PickleRick
Greenville sc
87 4 runner BHW swap, 2011 A3 tdi, several b5.5 bhw's.
Once you get it in see if the cruise control works. There's I believe a 10% error allowed by the ECU on the RPM vs speed. If it does work no need for a reflash. If it doesn't then it's time to reflash if you want cruise control
zzdiesel
Caffiene, do you have a part number for the pilot bearing?
zzdiesel
Can anybody tell me what the FHN does for rpm at 80 mph with stock tires? I am wondering if it is within thenten % that pickle mentioned. Maybe it would have to within 5%, 5 plus or minus making ten.
CantWrite
Placerville CO
Looking at old threads, a conversation between VWZIPS and 50harleyrider showed:
EEN: 2700 rpm @ 80mph (3.70 R&P)
FHN: 2450 rpm @ 80mph (3.44 R&P....?)
so right around that 10%, so prolly too close to call without installing and checking to see if cruise works as mentioned above. I’d error on the side of it won’t......
CantWrite
Placerville CO
3.7 minus 3.44 over 3.44 times 100 equals 7.55%
Sweet!! Your math must be better!! Not sure if 5th gear is the same....
I just did 2450/2700 = .9 - 1.0 = .1 or 10%
snark remark is not my intention if it’s taken that way.
zzdiesel
Further comparison, 5th times final drive.
Fhn---3.44x .686= 2.359
EEN---3.70x.683= 2.527
Percent differance is 7.1% So maybe
zzdiesel
Ok, update and a few thoughts:
The EEN bought on ebay from Spain arrived nine days from ordering.
I did not remove the clutch since it was new. The tranny slipped right in, easiest install ever. I think because of the perfect alighment.
Woo hoo, the cruise works. The shifting is silky smooth.
The clutch setup is a LUK dual mass flywheel, with M-pact 6 ceramic puck disc and pressure plate. It was around 500 bucks. About 2000 miles on the setup. It is slightly grabby on startup but not too bad. It seems to hold the stage two power. The puck disc is supposed to hold 30 to 40 percent more torque so they say. They also have stiiffer pressure plates available. Mine feels normal.
Because of the dual mass thesetup just seems smoother. The 18 1900 delete vibrations seem gone. I like it.
So, FHN tranny for sale. It looks good with the back case removed. Needs a synchro, this one was in 3 pieces.
Franz sold me the Valeo single mass flywheel setup. It was nice and smooth shifting. He said it would hold a stage two tune and it has. Would sell.
On too the next problem car. I bought a 2005 passat sedan for 800. The body and the interior very nice, decent tires, no oil pressure when reving. I just finished installing a used auto tranny into my B5.5 wagon. It seems good, no codes. I have five B5.5s, 4 tdis and a 4mo. Maybe tooo many cars. Also a 96 Celica and a nice 98 A4 2.8 Audi quatro
CantWrite
Placerville CO
How do you like the EEN ratios vs the FHN?
Mine (EEN) is still buzzy at 2k and below. So I try to drive at 2200 and above when under load. I also wanna raise my idle to 1k as that is much smoother.
yadic
United States
just looking
geometry dash breeze jugar gratis
When switching from an FHN to an EEN gearbox, you may need to recode the ECM due to different gear ratios, especially with the Malone tune. Check for fitment issues with mounts and driveshafts, and ensure you use the pilot bearing specific to the EEN gearbox. You might also need to recalibrate the speedometer and verify transmission mount compatibility.
caffeine
B.C., Canada
Why does this appear to be AI generated?
zzdiesel
CantWrite, I find I prefer the EEN. I would say less than five percent of my driving is on the freeway doing 80. That is about 2750 rpm. Most is local highway driving at 50 t0 70 mph. where the revs are more suitable above 2000 with the EEN.
Interestingly, from my very limlted research, the FHN was only used in the very early years in the B5. VW apparently thought lower geared trannys like the EEN were a better fit. Cosequently there are very few FHNs for sale used, and many more EENs etc.
As to the vibrations below 2000 rpm, it seems the dual mass flywheel has really smoothed that out.
The Cream Dolphin
Fernie, B.C. originally Dwight, ON
02 VW Golf TDI ALH 245k
Haha because it definitely is. See my compiled list of cars he claims to own...
2ⁿᵈreply in here. I think he is a bot. I was looking at his postings, and it got so funny, I kept going. Here is a list of the cars he "owns".
20̷15 chevrolet
Explorer
20̷18 e-class
20̷15 sportwagen
20̷21 highlander
Insight
20̷20̷ F250̷
20̷0̷7 Passat TDI (despite profile saying “just looking” under tdis)
1992 sc40̷0̷
1998 beetle ute
20̷0̷8 Tundra
Mercedes cls (due for Audi a3 service?)
20̷22 iX
Qx60̷
20̷23 Santa fe
20̷0̷5 Monaco dynasty diamond IV w/ cummins
Triumph sprint
Another bike, that has an EGR?
20̷0̷3 passat
All his replies are off topic and odd too.
Add to the list
Range Rover
'85 Silver spirit
Honda pioneer 10̷0̷0̷
