Changed glow plugs, no start. Primed pump, checked fuses.
roninisc
us
a3
2011, mk6, 8p
Hello all, Ive read this thread-- https://forums.tdiclub.com/index.ph...start-no-vcds-communication-wiith-ecm.512945/
-- but the symptoms dont quite match. I had my ECU changed out just last year, so I really hope it's not that again.
Was getting a bad plug error on VCDS (no plug light though) so changed it out this evening. While doing so, I decided to remove all the other plugs, clean, and test resistance. All were ok. Put them all back in at 11 ft/lbs.
The engine cranks but no start. Not a single ignition. There is good crank, batt is strong, I keep it charged w a trickle charger. It is about 68 degrees F. I was forced to remove the return fuel line when removing plugs and just a tiny dribble came out. I primed both front and rear pumps with VCDS 30 secs 6 times to no effect, I can hear both of them come on during prime test. I did take off the battery leads. I checked all fuses up top in the box next to battery, good.
I obviously had to run the second scan with engine not running, but with ignition on. Many of the errors are not relevant:
-The ABS and TPMS 'errors' will go away as soon as I drive it 50 feet.
-The immob and inst control mod errors have existed since mech put in the new ECU; no effect on driving.
-I think the HVAC is due to car not running?
Thanks!!
Thursday,08,August,2024,
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 24.5.0.0 (x64) HEX-V2 CB: 0.4643.4
Data version: 20240429 DS355.0
www.Ross-Tech.com
Chassis Type: FM-AU35 (8P0)
Scan: 01 02 03 08 09 0F 10 15 16 17 19 25 2E 37 42 44 46 4C 52 55
56 62 72 77
Mileage: 211570km-131463miles
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: OK 0000
0F-Digital Radio -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: Malfunction 0010
2E-Media Player 3 -- Status: OK 0000
37-Navigation -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: Malfunction 0010
46-Central Conv. -- Status: OK 0000
4C-Tire Pressure II -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine (CBE) Labels: 03L-906-022-CBE.clb
Part No SW: 03L 997 030 R HW: 03L 906 019 CT
Component: R4 2.0l TDI G000AG 9983
Revision: 12H14--- Serial number: AUX7Z0JNFNB07H
Coding: 0350078
Shop #: WSC 51279 002 1048576
VCID: 3D273452717E64527C5-8068
VINID: 9D195B69159DA124402091870CACB91375
No fault code found.
Readiness: 0 0 0 1 1
Address 02: Auto Trans Labels: 02E-927-770.clb
Part No SW: 02E 300 057 A HW: 02E 927 770 AL
Component: GSG DSG AG6 511 9334
Revision: 05351112 Serial number: 00001010260546
Coding: 0000020
Shop #: WSC 06314 000 00000
VCID: 176BC6FA33826E02869-8042
Address 03: ABS Brakes (J104) Labels:. 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 BG HW: 1K0 907 379 BG
Component: ESP MK60EC1 H31 0106
Revision: 00H31001
Coding: 1150400F492A0003881102EB921C0042BF0C00
VCID: 78A9E54612DC817A6F3-802C
1 Fault Found:
01325 - Control Module for Tire Pressure Monitoring (J502)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 205
Mileage: 211572 km
Time Indication: 0
Date: 2024.08.08
Time: 01:28:01
Freeze Frame:
Count: 2
Count: 14
Count: 4096
Count: 16390
Count: 42240
Count: 0
Count: 256
Count: 0
Address 08: Auto HVAC Labels: 8P0-820-043.lbl
Part No SW: 8P0 820 043 BN HW: 8P0 820 043 BN
Component: KlimavollautomatH09 0170
Revision: 000479 Serial number: 8P0820043BN
Shop #: WSC 00000 000 00000
VCID: 79AFE04225D6987210D-802C
4 Faults Found:
01299 - Diagnostic Interface for Data Bus (J533)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 3
Fault Frequency: 1
Reset counter: 245
Mileage: 0 km
Time Indication: 0
Freeze Frame:
ON
01317 - Control Module in Instrument Cluster (J285)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 245
Mileage: 0 km
Time Indication: 0
Freeze Frame:
ON
01301 - Control Module for Voice Recognition (J507)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 245
Mileage: 0 km
Time Indication: 0
Freeze Frame:
ON
01206 - Signal for Duration of Ignition Off Time
008 - Implausible Signal
Freeze Frame:
Fault Status: 01101000
Fault Priority: 3
Fault Frequency: 1
Reset counter: 205
Mileage: 211572 km
Time Indication: 0
Date: 2024.08.08
Time: 01:26:26
Freeze Frame:
Address 09: Cent. Elect. (J519) Labels:. 8P0-907-063.clb
Part No SW: 8P0 907 063 Q HW: 8P0 907 063 K
Component: BCM PQ35 M 107 0719
Revision: 00107 AF
Coding: 6E000A0FA01336E4287241E001100D4D407E62AA106DD128E40008840040
VCID: 42DD47AE04801BAA017-8016
Subsystem 1 - Part No SW: 8P1 955 119 F HW: 8P1 955 119 F Labels: 1KX-955-119.CLB
Component: Wischer AU350 H11 0050
Coding: 00DD13
Subsystem 2 - Part No SW: 8K0 910 557 HW: 8K0 955 559 A Labels: 8K0-955-559.CLB
Component: REGENLICHTSEN H04 0003
Coding: 024C2D
Subsystem 3 - Part No: 1K0 951 605 C
Component: LIN BACKUP HO H05 1501
Address 0F: Digital Radio Labels: 8E0-035-593-SIR.lbl
Part No SW: 8E0 035 593 P HW: 8E0 035 593 P
Component: SDAR SIRIUS H07 0160
Revision: 00000000 Serial number: AUZ4Z7K0590996
Coding: 0000100
VCID: 36352B7E5448B70ABDF-8062
Address 10: Park/Steer Assist (J446) Labels:. 8P0-919-475-7X1.clb
Part No SW: 8P0 919 475 M HW: 8P0 919 475 M
Component: PARKHILFE 4K H01 0140
Revision: 11001001 Serial number: 36891032101633
Coding: 000103
VCID: 48C9558622BC31FADF3-801C
Address 15: Airbags (J234) Labels:* 8P0-959-655-10.clb
Part No SW: 8P0 959 655 Q HW: 8P0 959 655 Q
Component: Airbag AU1042 H07 0200
Revision: -------- Serial number: 003FC001C3AD Dataset Number: 8P0909602N 0004
Coding: 303142393041303030374A55304C38503053
ASAM Dataset: EV_Airba10AURB4 001001
ROD: EV_Airba10AURB4_AU35.rod
VCID: 50F97DE6DA6CF93A873-8004
Seat occupied recognition:
Subsystem 1 - Part No SW: 8P0 910 339 C HW: 8P0 959 339 C
Component: BF-Gewichtss. H02 0030
Serial number: 5810000R0000005493
Coding: 000000
Crash sensor for side airbag: driver side:
Serial number: 3572DRB40000CFA07A52
Front Passenger's Side Airbag Crash Sensor:
Serial number: 3582DRB40000CFA8630+
Rear Side Airbag Crash Sensor (on driver's side):
Serial number: 35128RB400005EA5168O
Passenger side rear thorax airbag crash sensor:
Serial number: 35228RB400005EA8546S
Crash sensor for front airbag: driver side:
Serial number: 35547RB400005EE8D30.
Crash sensor for front airbag: front passenger side:
Serial number: 35647RB400005EE8D866
Address 16: Steering wheel Labels: 8P0-953-549.lbl
Part No SW: 8P0 953 549 K HW: 8P0 953 549 K
Component: J0527 H37 0070
Coding: 0014142
VCID: 46D55BBE24A8278A2DF-8012
Subsystem 1 - Part No: XXXXXXXXXXX
Component: E0221 H02 0100
Address 17: Instruments Labels: 8P0-920-xxx-17-MY8.clb
Part No SW: 8P0 920 982 S HW: 8P0 920 982 S
Component: KOMBIINSTR. VDO H01 0091
Revision: D0H01004 Serial number: 224NJ004002733
Coding: 0272288
Shop #: WSC 65536 645 577705
VCID: 49CF508235B6C8F2C0D-801C
1 Fault Found:
00003 - Control Module
005 - No or Incorrect Basic Setting / Adaptation
Freeze Frame:
Fault Status: 01100101
Fault Priority: 6
Fault Frequency: 1
Reset counter: 255
Mileage: 211572 km
Time Indication: 0
Date: 2024.08.08
Time: 01:28:00
Address 19: CAN Gateway (J533) Labels:. 7N0-907-530-V2.clb
Part No SW: 8P0 907 530 B HW: 1K0 907 951
Component: J533 Gateway H42 0311
Revision: H42 Serial number: 241010F1000173
Coding: 352102
VCID: 323D176EB420AB2A917-8066
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Revision: D0H01004 Serial number: AUX7Z0JNFNB07H
1 Fault Found:
01179 - Incorrect Key Programming
000 - -
Address 2E: Media Player 3 (R199) Labels:. 8T0-035-785.clb
Part No SW: 8P0 035 785 HW: 8P0 035 785
Component: SG ext.Player H08 0100
Revision: 00000000
Coding: 020302
VCID: 74B1D1760EB4E51A43B-8020
Address 37: Navigation Labels: 8E0-035-192-RNSE.clb
Part No SW: 8P0 035 193 F HW: 8P0 035 193 F
Component: RNS-E PU US H06 0210
Revision: 0000013S Serial number: AUZBZ7MD700654
Coding: 0209645
Shop #: WSC 08264 444 104937
VCID: 3333126A473AA2229A1-8066
Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN3.lbl
Part No SW: 8P0 959 801 Q HW: 8P0 959 801 Q
Component: Tuer-SG H04 0101
Coding: 0001213
Address 44: Steering Assist Labels: 1K0-909-14x-GEN3.clb
Part No: 1K0 909 144 J
Component: EPS_ZFLS Kl. 232 3001
Revision: 00H17000
Shop #: WSC 02069 000 90108
VCID: 313F1862BD269032E8D-8064
1 Fault Found:
03803 - Steering Angle Sensor for Steering Aid
000 - - - MIL ON
Freeze Frame:
Fault Status: 11100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 211572 km
Time Indication: 0
Date: 2024.08.08
Time: 01:28:00
Freeze Frame:
Battery Volts: 12.0 V
DD
Temperature: 23.0\B0C
Count: 2
Steering Angle: 0.00\B0
Count: 0
SteerAng n.Init
Address 52: Door Elect, Pass. Labels:. 1K0-959-702-MIN3.clb
Part No SW: 8P0 959 802 Q HW: 8P0 959 802 Q
Coding: 0001213
VCID: 4ACD6F8E30B0C3EAC97-801E
Address 55: Headlight Range Labels: 8P0-907-357.lbl
Part No: 8P3 907 357 B
Component: Dynamische LWR H02 0010
Revision: 00000001 Serial number:
Coding: 0000013
VCID: 3C2139566A646D5A4BB-8068
Address 56: Radio Labels: 8E0-035-192-RNSE.clb
Coding: 0209645
Address 62: Door, Rear Left Labels: 8P4-959-801.lbl
Part No SW: 8P4 959 801 F HW: 8P4 959 801 F
Component: Tuer-SG H04 0050
Coding: 0001176
Shop #: WSC 06314 000 1012544
VCID: 42DD47AE08801BAA017-8016
Address 72: Door, Rear Right Labels: 8P4-959-802.lbl
Part No SW: 8P4 959 802 F HW: 8P4 959 802 F
Coding: 0001176
VCID: 43D342AA179A12A20A1-8016
Address 77: Telephone Labels: 8P0-862-335.lbl
Part No SW: 8P1 862 336 HW: 8P1 862 336
Component: FSE_256x BT H41 0650
Revision: 00000000 Serial number: 00000005042229
Coding: 0011477
VCID: 75B7EC7209CEFC12745-8020
End----(Elapsed Time: 01:33, VBatt start/end: 11.8V/11.8V. VIgn 11.7V)-----
MrCypherr
Ontario
Mk6 Wagon
Got a quick video of it cranking over? Does it sound like theres any compression?
roninisc
us
a3
Dude, you have some magic internet mojo or something.
I must have cranked it 20 times at various points for decent lengths, even again this morning after letting it sit and extra-charging battery.. nothing. The outside temp now is even cooler than last night. As soon as I go again to take the vid, the thing turned over.
The only thing I did, again, was to remove the big relay 370 in the box and reinsert it. I've read that's the load reduction relay? which shouldn't play much of a role? (I always leave my lights off when starting anyway) Or is it something else and/or more relevant? I feel like it's probably coincidence, but who knows.
MrCypherr
Ontario
Mk6 Wagon
Wish I could say I had something magic LOL. Atleast it started hopefully it was just some air trapped somewhere and now its finally caught.
