Braga_Dub
Hello!
I just changed the fuel filter after going about 20-25K miles. Sort of slacked off on filter maintenance
I had a question...
I key cycled a few times to prime the filter (I have a lift pump) and turned the car on. It cranked perfectly, and ran fine for about 5 seconds, then the RPM jumped slighted and the motor died. I then key-cycled a few more times until there were no air bubbles in the fuel lines. (I should of checked for them before turning it on the first time...)
I then tried starting the car again.
It took about 2 seconds of cranking before the engine started, and then it ran perfectly fine for a minute or so, and then I shut it down. No air bubbles were present in the line.
So, is the engine alright? Or could this have caused damage?
I should have poured diesel into the filter first, but I did not want to pour the diesel that came out of the old filter into the new one.
I had a question...
