Central NM Roll Call
Wicked6
EAST valley Phx.
2000 Golf GLS TDi
NM IPA challenge heads up to SFBC this Friday from 4-8 pm. $25, 16 samples plus their commemorative glass filled with your favorite .... Then it heads down to Marble brewing co on Saturday. I would probably prefer heading to SFBC, but wouldnt be there til around 5. (Work gets in the way). :)
Wicked6
EAST valley Phx.
2000 Golf GLS TDi
LOL..... Yeah, I know..
Nothin wrong with cheap beer every once in a while to remind you how far we've come..!!!
So, it looks like I'll be attending for sure - with a couple of coworkers in tow..
Hendersonville, NC
2002 Jetta, 2003 jetta wagon
ToastyJosh,
I have never had work done by Konstruct, Brody at Speedlab in Albq has done lots of good work for my 2002 Jetta TDI. I have been very
pleased with his work.
Wicked6
EAST valley Phx.
2000 Golf GLS TDi
Doing a G60 / VR6 clutch in the Golf tomorrow..
Also gonna drop in a Boraparts 5 speed .658 gear mod.. (Couldnt afford RyanP's 6 speed upgrade.... :( bummed...)
Clutch started slipping once I put the Kerma DLC1019 nozzles in.. Not even a tune - yet.. :)
Wicked6
EAST valley Phx.
2000 Golf GLS TDi
VR6 / G60 clutch and .658 5th gear DONE
..........Getting there.....
Kerma's DLC1019's are cleaning up tremendously... (150HP, 216um nozzles) .........I like these a LOT... My stock injectors must have been hosed.! (tons of smoke, power was... "meh"...) I took advantage of Kerma's calibrated, "hot-swap" option.. HIGHLY recommended...! Now I gotta get going on a tune... (shooting for economy with this TDi... for now...)
VR6 / G60 clutch kit seems to be holding up just fine to the 1019's.. 3rd gear pulls and no slipping....! Again.. . . For now.. Forgot how much fun a clutch swap was. ;)
.658 5th gear is &*^@$%#$ EPIC.........!!!!!!!!!!!!!!!!!!!! Can't believe I waited this long to get it done, but I am stoked beyond words. For those who have stumbled across this thread, searching for some driveability notes: (BTW - go for it...! Boraparts has 'em in stock)
  • 40-45 mph crusing in 5th on a flat road is fine. 1200-1400 RPM. I was worried it would drop WAY too low. It holds 45-50 mph on a mild grade, but any serious 45 mph hills require 4th gear to accelerate. Or just hold it at 52. :D
  • 60-65 mph is perfect. ~1750 - 2000 RPM. Pulls cleanly to 75 / 80 mph for passing. I think the 1019's have me spoiled here...
I did think about the .681 gear - but gambled on "a little more". I'm glad I did..! Would probably be happy with a .681 - but would have wondered if I shoulda went .658.. I'd be in heaven with a 6 speed that had either a double over drive, or .700 / .658 5th / 6th gears...
Will post something similar in the transmission forum....
Linc
Bill405
NM
2006 jetta BRM
Another NM TDI owner. Will be doing a cam soon on BRM motor. I also have the VCDS for 05 and newer VW's. I had Forein Aide do my last timing belt. ummmm, I don't think they use a VCDS. My torsion was wayyyy off. Car runs great now and fuel mileage improved taboot.
abctdi
ABQ, NM, USA
2005 Passat GLS
Where are you located?
toastyjosh
Northern NM
2003 silver 2door golf
Linc
Thats great! I just got a malone stage 1 tune and I am super stoked.
Glad your .681 swap worked out.
bbexotics
albuquerque
2004 Passat,2006 Jetta, 2003 Jetta wagon, 2017 Cayman S
Been here all along joined way back in 2000,rejoined in 2012,harvieux in cali bought my first 1996 passat tdi,when he was getting started,how time flies!!!
4ME+N02
NM
2002 JETTA
Western NM
I am in Milan, NM.
First time to this part of the forum.
2002 Jetta TDI
KRGVW
Albuquerque, NM
2001 Jetta
Another 1 for Albuquerque, NM.
Gotta a timing belt/water pump job coming up in the next couple weekends.
Anyone in town with VAG-COM and/or ALH tools that takes beer as payment?:D
ultrastevep
Cookville, TX
None presently, have owned VW TDI's since my first in 2000
TB in ABQ
I don't have the Vag-com, but I wanted to mention that I just had my timing belt done (265K) on my 2002 Golf at Hans Wittler's. $1100. Good thing about this is they discovered a cam seal leak and replaced that while in there. These guys are good and know our TDI's...:)
http://www.hanswittlerauto.com/
KRGVW
Albuquerque, NM
2001 Jetta
Thank you for the recommendation! I think that might have been the only place I didn't call while I shopped around before I decided to order my kit and brave it on my own. Thanks again!
abctdi
ABQ, NM, USA
2005 Passat GLS
You should have no problem doing it with good directions and tools. I did mine w/o vagcom and it's a 2005.
Good luck.
ultrastevep
Cookville, TX
They do a great job over at Hans Wittler, I'll let no one else in ABQ touch my engine. Ask for Andreas...
Good luck with it!
Steve
bbexotics
albuquerque
passat is running great,also the wifes jetta.Had to change the dmf,and was due fro timing belt,got both done at the same time.Son just sold his 2002 jetta tdi,and I sold my dads 1996 passat a couple of months ago.The old passat will be missed,that thing is bulletproof.
bbexotics
albuquerque
want you to know that I found a killer deal on a febi cam with hardened tappets etc,if you will be needing a cam,let me know and I will send you info.
abctdi
ABQ, NM, USA
2005 Passat GLS
I will eventually, being a PD and all. I observed lobe wear 20k miles ago and expected lifter noise, but all is quiet. Using Rotella T6 may be helping.
I'll PM you with an email address, thanx.
KRGVW
Albuquerque, NM
2001 Jetta
Anyone have compression testing tools up in La 'Burque area? Wrecked my Jetta "all sick" and I'd like to run some tests on the engine before I scrap it. PM if you have them or know where to get them.
