central electrics faults and general weird stuff happening Please HELP!
nowback
alberta canada
tdi's ranging 2000 golf to 2006 jetta 7 in total:)
2006 jetta tdi with some really weird stuff going on.
starts with the cig lighter quitting (dash can quits)
then heater stops
followed by power windows, power mirrors, signal lights, remote trunk and gas door.
things have progressed and if one continues driving the engine will
eventually die and power steering is also lost at that time long with brake
lights. its hard to believe that so many systems die in a cascade of failures!
you would think the engineers would put a little more value on the importance
of the brake lights when the engine fails!
i checked codes doing a full scan and with the command start connected the list is longer but with it now removed to narrow down the issue
it has come down to this scan. although a longer drive might have resulted in more faults. seems the hotter the day outside the faster the faults pile up.
here is the cut n p of the scan:
Sunday,27,September,2015,12:17:57:59579
VCDS -- Windows Based VAG/VAS Emulator Running on Windows XP x86
VCDS Version: 15.7.1.0
Data version: 20150904
www.Ross-Tech.com
VIN: 3VWGT81K06M058178 License Plate: NOEL3
Mileage: 256970km-159673mi Repair Order:
Chassis Type: 1K (1K0)
Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72 7D
VIN: 3VWGT81K06M058178 Mileage: 256970km-159673miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: OK 0000
15-Airbags -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: Malfunction 0010
56-Radio -- Status: OK 0000
7D-Aux. Heat -- Status: OK 0000
Address 01: Engine Labels: 038-906-016-BEW.lbl
Part No SW: 03G 906 016 AC HW: 028 101 223 9
Component: R4 1,9L EDC G000DG 7551
Revision: --H05--- Serial number: VWZ7Z0F4544963
Coding: 0050078
Shop #: WSC 00066 000 00000
VCID: 64CDB5F1A7B3041ED9-8030
No fault code found.
Readiness: 0 0 0 0 0
Address 02: Auto Trans Labels: 02E-927-770.lbl
Part No SW: 02E 300 043 HW: 02E 927 770 AE
Component: GSG DSG 070 1126
Revision: 04507000 Serial number: 00000607070561
Coding: 0000020
VCID: 51A36C25C80181B682-8004
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No SW: 1K0 907 379 AC HW: 1K0 907 379 AC
Component: ESP FRONT MK60 0101
Revision: 00H11001
Coding: 0021122
VCID: 73EFC6AD125D93A650-8026
Address 08: Auto HVAC Labels: 1K0-820-047.lbl
Part No: 1K0 820 047 FJ
Component: Climatic PQ35 120 0606
Shop #: WSC 00000 000 00000
VCID: 71E3CCA56841A1B6A2-8024
Address 09: Cent. Elect. Labels: 3C0-937-049-23-M.lbl
Part No SW: 3C0 937 049 P HW: 3C0 937 049 P
Component: Bordnetz-SG H46 1501
Revision: 00H46000 Serial number: 00000000439073
Coding: 10018E234004150007140000001400000008730B5C0000
VCID: 36693FB941AFC68EB7-8062
Subsystem 1 - Part No: 1K1 955 119 E Labels: 1KX-955-119.CLB
Component: Wischer 270906 020 0501
Coding: 00038805
Shop #: WSC 00066
2 Faults Found:
00093 - Terminal 15 for Starting Relevant Consumers
008 - Implausible Signal
Freeze Frame:
Fault Status: 01101000
Fault Priority: 2
Fault Frequency: 2
Reset counter: 8
Mileage: 256911 km
Time Indication: 0
Freeze Frame:
OFF
Voltage: 13.90 V
ON
ON
OFF
OFF
OFF
02403 - Terminal 15 for Interior
006 - Short to Plus
Freeze Frame:
Fault Status: 01100110
Fault Priority: 2
Fault Frequency: 2
Reset counter: 8
Mileage: 256911 km
Time Indication: 0
Freeze Frame:
OFF
Voltage: 13.90 V
ON
ON
OFF
OFF
OFF
Address 15: Airbags Labels: 1K0-909-605.lbl
Part No SW: 1K0 909 605 AB HW: 1K0 909 605 AB
Component: 6C AIRBAG VW8R 034 8000
Revision: 05034000 Serial number: 003B6D05WCD9
Coding: 0013891
VCID: 6CDDDDD14F634C5E91-8038
Subsystem 1 - Serial number: 6332MSME121A7E74H
Subsystem 2 - Serial number: 6342MSME1251677FG
Subsystem 3 - Serial number: 6351HSME0A591B3BH
Subsystem 4 - Serial number: 6361HSME0A6362566
Subsystem 5 - Serial number: 63727SME0A565251.
Subsystem 6 - Serial number: 63827SME0A5F12510
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 AR HW: 1K0 953 549 AR
Component: J0527 035 0070
Coding: 0010021
VCID: 020193695DE7AA2E4B-8056
Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
Part No SW: 1K0 920 853 K HW: 1K0 920 853 K
Component: KOMBIINSTRUMENT 3HL 1610
Revision: V0003000 Serial number: VWZ7Z0F4544963
Coding: 0023303
Shop #: WSC 91590 999 52559
VCID: 326103A9ADC7DAAE9B-8066
Address 19: CAN Gateway Labels: 1K0-907-530-V2.clb
Part No SW: 1K0 907 530 H HW: 1K0 907 951
Component: J533__Gateway H12 0150
Revision: H12 Serial number: 31001068020403
Coding: 3F3F0B4007001002
VCID: 2C5D1DD18FE38C5ED1-8078
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Component: IMMO 3HL 1610
Address 42: Door Elect, Driver
Cannot be reached
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K1 909 144 L
Component: EPS_ZFLS Kl.070 H07 1806
Shop #: WSC 02069 000 90108
VCID: 346D05B157D3D49E89-8060
Address 46: Central Conv.
Cannot be reached
Address 52: Door Elect, Pass.
Cannot be reached
Address 56: Radio
Cannot be reached
Address 62: Door, Rear Left
Cannot be reached
Address 72: Door, Rear Right
Cannot be reached
Address 7D: Aux. Heat Labels: 1K0-963-235.lbl
Part No SW: 1K0 963 235 E HW: 1K0 963 235 E
Component: PTC-Element 0404
Revision: 00800000 Serial number:
VCID: 2D5B10D5B4F98556C6-8078
End-------------------------(Elapsed Time: 02:01)--------------------------
nowback
alberta canada
first scan after a drive when the engine died before the key was turned off.
turning the key off and letting the car rest for a bit everything starts to work again
sometimes everything works sometimes some stuff doesnt its different each occurrence
Thursday,24,September,2015,21:12:29:59579
VCDS Version: 14.10.2.0
Data version: 20150311
www.Ross-Tech.com
Mileage: 256770km-159549mi Repair Order:
VIN: 3VWGT81K06M058178 Mileage: 256770km-159549miles
02-Auto Trans -- Status: Malfunction 1010
03-ABS Brakes -- Status: Malfunction 0010
08-Auto HVAC -- Status: Sporadic communication error 1000
15-Airbags -- Status: Sporadic communication error 1000
16-Steering wheel -- Status: Malfunction 0010
25-Immobilizer -- Status: Malfunction 0010
44-Steering Assist -- Status: Sporadic communication error 1000
46-Central Conv. -- Status: Malfunction 1010
62-Door, Rear Left -- Status: Malfunction 0010
Coding: 0050078
VCID: 64CDB5F1A7B30401EA7-8031
Coding: 0000020
VCID: 51A36C25C80181A9B11-8004
1 Fault Found:
28775 - No Communication with Gear Selector Module
U0103 - 000 - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 0
Fault Frequency: 255
Reset counter: 33
Mileage: 256497 km
Time Indication: 0
Revision: 00H11001
Coding: 0021122
VCID: 73EFC6AD125D93B963D-8026
1 Fault Found:
01309 - Power Steering Control Module (J500)
VCID: 71E3CCA56841A1A9911-8024
VCID: 36693FB941AFC691843-8063
Coding: 00038805
Shop #: WSC 00066
2 Faults Found:
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 2
Fault Frequency: 31
Reset counter: 45
Mileage: 256497 km
Time Indication: 0
Freeze Frame:
OFF
Voltage: 13.65 V
ON
ON
OFF
OFF
OFF
006 - Short to Plus - Intermittent
Freeze Frame:
Fault Status: 00100110
Fault Priority: 2
Fault Frequency: 27
Reset counter: 45
Mileage: 256497 km
Time Indication: 0
Freeze Frame:
OFF
Voltage: 13.65 V
ON
ON
OFF
OFF
OFF
Coding: 0013891
VCID: 6CDDDDD14F634C41A27-8039
Coding: 0010021
VCID: 020193695DE7AA3178B-FFFF
Coding: 0023303
VCID: 326103A9ADC7DAB1A8B-8067
VCID: 2C5D1DD18FE38C41E27-8079
5 Faults Found:
01330 - Central Control Module for Central Convenience (J393)
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 2
Reset counter: 37
Mileage: 256497 km
Time Indication: 0
Date: 2000.00.00
Time: 03:14:29
01320 - Control Module for Climatronic (J255)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 37
Mileage: 256497 km
Time Indication: 0
Date: 2000.00.00
Time: 03:15:38
01321 - Control Module for Airbags (J234)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 37
Mileage: 256497 km
Time Indication: 0
Date: 2000.00.00
Time: 03:17:53
Freeze Frame:
Fault Priority: 2
Fault Frequency: 4
Reset counter: 45
Mileage: 256497 km
Time Indication: 0
Date: 2000.00.00
Time: 03:27:20
01315 - Transmission Control Module
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 37
Mileage: 256497 km
Time Indication: 0
Date: 2000.00.00
Time: 03:27:53
1 Fault Found:
01176 - Key
Freeze Frame:
Fault Priority: 2
Fault Frequency: 4
Reset counter: 255
Mileage: 31987 km
Time Indication: 0
Date: 2000.00.00
Time: 03:15:07
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN3.lbl
Part No SW: 1K0 959 701 P HW: 1K0 959 793 L
Component: J386 TUER-SG FT 1127
Revision: 12007001 Serial number: 00000584968925
Coding: 0001205
VCID: 3B7F2E8D7A8D1BF97BD-806E
4 Faults Found:
00932 - Electric Window Motor; Drivers Side (V147)
005 - No or Incorrect Basic Setting / Adaptation - Intermittent
Freeze Frame:
Fault Status: 00100101
Fault Priority: 3
Fault Frequency: 1
Reset counter: 41
Mileage: 0 km
Time Indication: 0
00928 - Locking Module for Central Locking; Front Driver Side (F220)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 254
Reset counter: 5
Mileage: 195985 km
Time Indication: 0
00105 - Signal Central Locking SAVE/LOCK Drivers Side
Freeze Frame:
Fault Priority: 3
Fault Frequency: 38
Reset counter: 43
Mileage: 254645 km
Time Indication: 0
Freeze Frame:
Fault Priority: 4
Fault Frequency: 2
Reset counter: 38
Mileage: 256497 km
Time Indication: 0
VCID: 346D05B157D3D481BA7-8061
Address 46: Central Conv. Labels: 1K0-959-433-MAX.clb
Part No SW: 1K0 959 433 CA HW: 1K0 959 433 CA
Component: KSG PQ35 G2 020 0202
Revision: 00020000 Serial number: 00000000000000
Coding: 1F900F880106083F0D040F8FB0880F0488FCA0
Shop #: WSC 00066 123 12345
Subsystem 1 - Component: Sounder n.mounted
Subsystem 2 - Component: NGS n.mounted
Subsystem 3 - Component: IRUE n.mounted
2 Faults Found:
00830 - Convertible Top Control Module (J256)
Freeze Frame:
Fault Status: 00110100
Fault Priority: 4
Fault Frequency: 1
Reset counter: 38
Mileage: 256497 km
Time Indication: 0
Date: 2000.00.00
Time: 03:14:36
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 38
Mileage: 256497 km
Time Indication: 0
Date: 2000.00.00
Time: 03:15:39
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl
Part No SW: 1K0 959 702 P HW: 1K0 959 792 L
Component: J387 TUER-SG BT 1127
Revision: 12007001 Serial number: 00000563068925
Coding: 0001204
VCID: 3C7D2D917F831CC1727-8069
3 Faults Found:
00933 - Electric Window Motor; Passenger Side (V148)
Freeze Frame:
Fault Status: 01100101
Fault Priority: 3
Fault Frequency: 1
Reset counter: 5
Mileage: 0 km
Time Indication: 0
00110 - Right Mirror Turn Signal Lamp (L132)
012 - Electrical Fault in Circuit
Freeze Frame:
Fault Status: 01101100
Fault Priority: 5
Reset counter: 5
Mileage: 249278 km
Time Indication: 0
Freeze Frame:
Fault Priority: 4
Fault Frequency: 2
Reset counter: 38
Mileage: 256497 km
Time Indication: 0
Address 56: Radio Labels: 1K0-035-161.lbl
Part No SW: 1K0 035 161 B HW: 1K0 035 161 B
Component: Radio DE2 014 0017
Revision: 00014000 Serial number: VWZ4Z7F6166885
Coding: 0040401
VCID: 1E39C719C95F6ED17C3-804B
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN3.lbl
Part No SW: 1K0 959 703 Q HW: 1K0 959 795 J
Component: J388 TUER-SG HL 1115
Revision: 12004001 Serial number: 00000000298069
Coding: 0001168
VCID: 3E792799699F0ED15C3-806B
1 Fault Found:
00934 - Electric Window Motor; Rear Left (V26)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 41
Mileage: 0 km
Time Indication: 0
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN3.lbl
Part No SW: 1K0 959 704 Q HW: 1K0 959 794 J
Component: J389 TUER-SG HR 1115
Revision: 12005001 Serial number: 00000000369924
Coding: 0001168
VCID: 3F875A9D6E9507D9575-806A
VCID: 2D5B10D5B4F98549F59-8078
End-------------------------(Elapsed Time: 04:29)--------------------------
Bob S.
Central MD.
A B4V, some ALHs & BRMs
Try cleaning all the grounds in the engine space (and I mean all of them) and 12VDC power buss and fusible link connections on the forward face of the engine space power relay box.
nowback
alberta canada
where is this : ??
006 - Short to Plus
I assume the central electrics is responsible for shutting stuff down. how does it know what to shut down? could this be an issue with the k line somewhere along its path?
I am at a loss as to where to even start.
I had an experience where a deer hit a headlight (or was it the headlight hit the deer) it shorted out the wiring and that circuit was shut down until the code was cleared
is its like something is telling central electrics that there are shorts all over the place and its shutting things down?
matt
nowback
alberta canada
one more thing! there is a persistent fault with the pass side door that doesnt clear all the time. could this be the the troublesome wiring in the door jam causing all this on one side of the other??
Random_Vibration
Florida
2015 Golf SEL TDI (6MT, LP, Driver Assist)
how and where could one short to ground effect so many systems??
matt
How: one ground fault can cause multiple system failure just by making one module malfunction. It pulls the others down with it. It's not a remote possibility and happens here and there if you car to search the web for similar situations.
Where: you probably have a chafed wiring harness somewhere. That's where I would start looking. The door is an excellent place to start.
Ol'Rattler
PNA
2006 BRM Jetta
A bad ground is something that could be in common with all the faults you have. On the 2006 BRM, there is a major chassis ground that works loose underneath the air cleaner box that could cause most if not all of your problems.
Pull the air box and look for an acorn nut that bolts 2 wires to the chassis.
I would not blame VW engineers for your lack of keeping up on proper maintenance.
nowback
alberta canada
i will check that out. gut feeling that this isnt where the issue is though.
matt
Bob S.
Central MD.
Clean every ground in the engine bay, & under the plenum shield along with the 12VDC+ connections & fuses on the front end of the engine fuse box.
nowback
alberta canada
did all of the above as well as disconnecting the aftermarket remote starter and same thing happened. seems temp related! its getting colder here and it takes much longer for the problem to show up.
matt
Henrick
Ireland
Golf VI TDI, 77 kW (CAYC)
Have you already checked the door wiring harness inside the boot, driver's door? Very common place for shorts, broken wires, etc.
nowback
alberta canada
yes check inside the boots on both sides. i was really expecting to see a problem in the drivers door but nothing.
matt
N.CaTDI
NorthBay San Francisco, CA
2005.5 Jetta
I doubt this could be it but easy to check. Earlier Jetta could get coolant into the wiring harness via the level sensor on the coolant tank. This ruined the harness and caused all sorts of problems. To check just unplug level sensor at coolant tank and see if fluid is collecting there. Also I assumed you checked for wear of the wiring harness when you cleaned the grounds.
nowback
alberta canada
yes that was one of the first things i checked because of all the weird stuff happening with this car i almost expected it to have the coolant problem but no its dry
nowback
alberta canada
worked on this car a bunch more today and swapped out the other 460 realy and that made no change. opened up the floor area on the pass side front and checked the grounds there they were all good. one thing to note the signal light leds in the pass side mirror had been very dim all the time. i checked the wiring to the door and its all good and doing so didnt change the dim mirror signal light. while i was under there i wiggled the wiring going to the heater fan and the fan speed resistor and bingo! the pass side turn signal is bright again! another note these problems only show their face when the car has warmed up and been driven for an hour or more once its warm it can be worked on to try to find the problem. so unsure if things just cooled off when i wiggled the heater wires and that caused it to work rite again or if it cooled off...
nowback
alberta canada
no insight at all on this issue??
Jesus Is Lord
Hersey, MI
2005 Passat TDI Wagon 144,000 2003 Eurovan VR6 2007 Touareg V10 TDI 158,000
Did you check the ccm connections. The module is just behind the glove box.
nowback
alberta canada
this makes more sense !
since i was moving the wiring around that connects
to the heater fan and the fan resistor it likely moved the ccm wiring as well
i will check that next. seems since i moved the wiring around at the fan the weird issues haven't shown up..
matt
nowback
alberta canada
matt
so i removed the glove box and messed around with the wires going to
what ever that box is behind the glove box and i am convinced the problem
isnt here.
had a chance to talk to a long time vw mechanic and he figures its the j539
or what he called the vehicle electronic control module which is under the steering column . yet to get into this item.
kind of wondering if this is a part that can be pulled from a wreck and
swapped in to see if it fixes the problem with out having to be coded to the
car.
nowback
alberta canada
doing some searching on the forum it would appear that the module under the column is the steering control module .
could this be the issue causing the weird problems.
leave it to the vw mechanic to come out with an idea that is totally wrong?
justintime_3
Bloomington,IL
2000 tdi Jetta, 2006 tdi jetta PKG 2
Please Please Please come back here and post up what you find. It is so frustrating reading through a whole post about the same problem you are having and find out the OP never came back to update on his findings and what fixed the problem.
Not to sidetrack but I am having a similar problem but my post is not getting the traffic that yours is. I am getting the drivers side door open and closing on its own with no rhyme or reason. Replaced drivers side door harness and all door control modules on all four doors along with the drivers side twice. And still the same problem.
And to you most recent post I believe the mechanic should have said the central convenience module that is located behind the glove box. The one you were messing with. I do not think the steering control module would affect all of the things that are going on with your car.
nowback
alberta canada
have you changed the latch assembly in the drivers door? seems to me
that its likely the micro switches in the mechanism. no?
matt
justintime_3
Bloomington,IL
Okay! So maybe I am misspeaking on the items that were replaced. I thought that the door latches were actually the door control modules. So all four "door latches" have been replaced. Unfortunately I will be taking it to the dealer today and see if they can bend me over backwards and narrow down what may be causing this. Thanks though
nowback
alberta canada
post up what you find out. as far as i know it has to be the latch
MyAvocation
Hoffman Estates, IL
2017 Passat SEL TSI
As far as I recall, A5 door latches don't contain micro switches, unlike A4. They instead have a cheap, non-servo type, motor for un/locking.
nowback
alberta canada
have you had any luck with this issue?
i have changed the module under the steering column as well as the signal light lever and the dim pass side mirror signal is still dim.
if driven more and more stuff shuts off.
no idea what to try next. i am thinking of plugging in a door off a parts car to the pass side and seeing if the dim mirror signal remains .
thing is if i bang around the area of the signal light lever the led in the
mirror will sometimes get brighter for a split second..
justintime_3
Bloomington,IL
Nope I have not gotten anywhere. I took it to the dealer and wasted 65 dollars as they programmed my key instead of doing what I asked (long story). After complaining long enough they invited me back down to have a look at it for free, after I got there the car was acting completely normal. So they took the car to the back of the shop and I went and waited in the break room. After about 35 minutes the manager comes and gets me and says can you come out here and speak to the tech that is working on your car. I said absolutely that's what I wanted this whole time. So after speaking to the tech he states I am the electrical guru here and I cannot get it to act up. So after talking to him for ten minutes, telling him everything I have already done he unplugs his VCDS (yes factory dealership using VCDS I didn't think they used this) and closes the door the damn thing starts flashing open door from the MFD display. So he plugs VCDS back in and goes to the controller and it is showing that the door is opening and closing and that the computer is registering it every time it does this even though the door is closed. He tells me that he doesn't know what to do. He states that he would have done everything that I have already done. Door Harness, clean all grounds in the engine bay, door latch mechanisms. And that the only thing that I have not done to check would be that there is a ground behind the kick panel on the drivers side that he knows can be problematic or to replace the control module under the steering wheel or the window regulator that has a door control module connected to it. So that is where I stand. I have not had time to dig into this any further but I will def be back here to update if I do end up finding out what the cause is. I have been leaning more to the module that is connected to the window regulator as there is no rhyme or reason for the way it is acting. Its not like a hard bump or closing a door changes the way it acts. It just does it completely on its own. I drive an hour to work everyday and there is just absolutely no consistency. And I am sorry I don't mean to derail your problems on your post.
Forgot to state that the guys at Ross Tech have been helpful in stating that the would look into modules #42 and #52 which have been known to be problematic.
