nowback
2006 jetta tdi with some really weird stuff going on.
starts with the cig lighter quitting (dash can quits)
then heater stops
followed by power windows, power mirrors, signal lights, remote trunk and gas door.
things have progressed and if one continues driving the engine will
eventually die and power steering is also lost at that time long with brake
lights. its hard to believe that so many systems die in a cascade of failures!
you would think the engineers would put a little more value on the importance
of the brake lights when the engine fails!
i checked codes doing a full scan and with the command start connected the list is longer but with it now removed to narrow down the issue
it has come down to this scan. although a longer drive might have resulted in more faults. seems the hotter the day outside the faster the faults pile up.
here is the cut n p of the scan:
Sunday,27,September,2015,12:17:57:59579
VCDS -- Windows Based VAG/VAS Emulator Running on Windows XP x86
VCDS Version: 15.7.1.0
Data version: 20150904
www.Ross-Tech.com
VIN: 3VWGT81K06M058178 License Plate: NOEL3
Mileage: 256970km-159673mi Repair Order:
Chassis Type: 1K (1K0)
Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72 7D
VIN: 3VWGT81K06M058178 Mileage: 256970km-159673miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: OK 0000
15-Airbags -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: Malfunction 0010
56-Radio -- Status: OK 0000
7D-Aux. Heat -- Status: OK 0000
Address 01: Engine Labels: 038-906-016-BEW.lbl
Part No SW: 03G 906 016 AC HW: 028 101 223 9
Component: R4 1,9L EDC G000DG 7551
Revision: --H05--- Serial number: VWZ7Z0F4544963
Coding: 0050078
Shop #: WSC 00066 000 00000
VCID: 64CDB5F1A7B3041ED9-8030
No fault code found.
Readiness: 0 0 0 0 0
Address 02: Auto Trans Labels: 02E-927-770.lbl
Part No SW: 02E 300 043 HW: 02E 927 770 AE
Component: GSG DSG 070 1126
Revision: 04507000 Serial number: 00000607070561
Coding: 0000020
VCID: 51A36C25C80181B682-8004
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No SW: 1K0 907 379 AC HW: 1K0 907 379 AC
Component: ESP FRONT MK60 0101
Revision: 00H11001
Coding: 0021122
VCID: 73EFC6AD125D93A650-8026
Address 08: Auto HVAC Labels: 1K0-820-047.lbl
Part No: 1K0 820 047 FJ
Component: Climatic PQ35 120 0606
Shop #: WSC 00000 000 00000
VCID: 71E3CCA56841A1B6A2-8024
Address 09: Cent. Elect. Labels: 3C0-937-049-23-M.lbl
Part No SW: 3C0 937 049 P HW: 3C0 937 049 P
Component: Bordnetz-SG H46 1501
Revision: 00H46000 Serial number: 00000000439073
Coding: 10018E234004150007140000001400000008730B5C0000
VCID: 36693FB941AFC68EB7-8062
Subsystem 1 - Part No: 1K1 955 119 E Labels: 1KX-955-119.CLB
Component: Wischer 270906 020 0501
Coding: 00038805
Shop #: WSC 00066
2 Faults Found:
00093 - Terminal 15 for Starting Relevant Consumers
008 - Implausible Signal
Freeze Frame:
Fault Status: 01101000
Fault Priority: 2
Fault Frequency: 2
Reset counter: 8
Mileage: 256911 km
Time Indication: 0
Freeze Frame:
OFF
Voltage: 13.90 V
ON
ON
OFF
OFF
OFF
02403 - Terminal 15 for Interior
006 - Short to Plus
Freeze Frame:
Fault Status: 01100110
Fault Priority: 2
Fault Frequency: 2
Reset counter: 8
Mileage: 256911 km
Time Indication: 0
Freeze Frame:
OFF
Voltage: 13.90 V
ON
ON
OFF
OFF
OFF
Address 15: Airbags Labels: 1K0-909-605.lbl
Part No SW: 1K0 909 605 AB HW: 1K0 909 605 AB
Component: 6C AIRBAG VW8R 034 8000
Revision: 05034000 Serial number: 003B6D05WCD9
Coding: 0013891
VCID: 6CDDDDD14F634C5E91-8038
Subsystem 1 - Serial number: 6332MSME121A7E74H
Subsystem 2 - Serial number: 6342MSME1251677FG
Subsystem 3 - Serial number: 6351HSME0A591B3BH
Subsystem 4 - Serial number: 6361HSME0A6362566
Subsystem 5 - Serial number: 63727SME0A565251.
Subsystem 6 - Serial number: 63827SME0A5F12510
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 AR HW: 1K0 953 549 AR
Component: J0527 035 0070
Coding: 0010021
VCID: 020193695DE7AA2E4B-8056
Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
Part No SW: 1K0 920 853 K HW: 1K0 920 853 K
Component: KOMBIINSTRUMENT 3HL 1610
Revision: V0003000 Serial number: VWZ7Z0F4544963
Coding: 0023303
Shop #: WSC 91590 999 52559
VCID: 326103A9ADC7DAAE9B-8066
Address 19: CAN Gateway Labels: 1K0-907-530-V2.clb
Part No SW: 1K0 907 530 H HW: 1K0 907 951
Component: J533__Gateway H12 0150
Revision: H12 Serial number: 31001068020403
Coding: 3F3F0B4007001002
VCID: 2C5D1DD18FE38C5ED1-8078
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Component: IMMO 3HL 1610
Address 42: Door Elect, Driver
Cannot be reached
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K1 909 144 L
Component: EPS_ZFLS Kl.070 H07 1806
Shop #: WSC 02069 000 90108
VCID: 346D05B157D3D49E89-8060
Address 46: Central Conv.
Cannot be reached
Address 52: Door Elect, Pass.
Cannot be reached
Address 56: Radio
Cannot be reached
Address 62: Door, Rear Left
Cannot be reached
Address 72: Door, Rear Right
Cannot be reached
Address 7D: Aux. Heat Labels: 1K0-963-235.lbl
Part No SW: 1K0 963 235 E HW: 1K0 963 235 E
Component: PTC-Element 0404
Revision: 00800000 Serial number:
VCID: 2D5B10D5B4F98556C6-8078
End-------------------------(Elapsed Time: 02:01)--------------------------
then heater stops
www.Ross-Tech.com
Coding: 0050078
Coding: 0000020
Revision: 00H11001
Coding: 0021122
Coding: 00038805
Shop #: WSC 00066
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 8
Mileage: 256911 km
Time Indication: 0
Freeze Frame:
OFF
Voltage: 13.90 V
ON
ON
OFF
OFF
OFF
006 - Short to Plus
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 8
Mileage: 256911 km
Time Indication: 0
Freeze Frame:
OFF
Voltage: 13.90 V
ON
ON
OFF
OFF
OFF
Coding: 0013891
Coding: 0010021
Coding: 0023303
Cannot be reached
Cannot be reached
Cannot be reached
Address 56: Radio
Cannot be reached
Cannot be reached
Cannot be reached
