Just got a check engine light on our 2009 Sportwagen. I did a quick search and on this forum and came up with nothing. Does anyone have a clue? Looks like the Exhaust pressure sensor 2 is shorted. I'm going to clear it and see if it comes back. Here is what it reads from VCDS:
2 Faults Found:
001146 - Exhaust Pressure Sensor 2: Open Circuit
P047A - 000 - - - MIL ON
Freeze Frame:
Fault Status: 11100000
Fault Priority: 2
Fault Frequency: 18
Mileage: 70248 km
Time Indication: 0
Date: 2000.00.00
Time: 17:27:36
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Temperature: 13.5°C
Temperature: 70.2°C
Temperature: 54.0°C
Pressure: 0 mbar
Pressure: 0 mbar
001025 - EGR System: Insufficient Flow
P0401 - 000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 2
Fault Frequency: 1
Mileage: 70248 km
Time Indication: 0
Date: 2000.00.00
Time: 17:27:24
Freeze Frame:
RPM: 1173 /min
Speed: 12.0 km/h
Voltage: 13.91 V
Load: 56.9 %
Load: 100.0 %
Mass Air / Rev.: 200.0 mg/str
Mass Air / Rev.: 205.0 mg/str
Readiness: 1 1 0 0 0
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 18
Mileage: 70248 km
Time Indication: 0
Date: 2000.00.00
Time: 17:27:36
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Temperature: 13.5°C
Temperature: 70.2°C
Temperature: 54.0°C
Pressure: 0 mbar
Pressure: 0 mbar
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 70248 km
Time Indication: 0
Date: 2000.00.00
Time: 17:27:24
Freeze Frame:
RPM: 1173 /min
Speed: 12.0 km/h
Voltage: 13.91 V
Load: 56.9 %
Load: 100.0 %
