CEL on trying to get through emissions.
T.J.
LLAz0135206@
2011 TDI Sportwagen
Trying to get my 2011 Sportwagen through emissions but the check engine light is on. Here are the faults it has. I can’t seem to find a definitive answer to what they are for. Any help would be greatly appreciated.
2BA600H/2860544
1A5800H/1726464
Post the more commonly used OBD2 format DTCs. If you do a quick search here with those instead, you'll likely find what you are looking for.
Starting with possibly a thermostat.
T.J.
LLAz0135206@
2011 TDI Sportwagen
Thank you for your response. If I had the common codes I would’ve posted them. This is what comes up on my snap on scanner. I searched these faults on here with no results.
Lightflyer1
Round Rock, Texas
2015 Beetle tdi dsg
Find another scanner. AutoZone scans for free I am told. Any generic scanner should work for check engine light codes. Get something useable. Or check with Snap On for the code explanation. Seems you have a NOX issue for some reason, when I search Google.
T.J.
LLAz0135206@
2011 TDI Sportwagen
updated still can’t get p-code I did however get these. 11174 and 6744 any info would be appreciated.
turbodieseldyke
Free Mustache Rides
Big ol' honkin' tdis
i suspected your first scanner added extra 00 to the codes.
decimal => hexadecimal
11174 => P2BA6
06744 => P1A58
Searching for those 2 P-codes should give you a good start.
P2B
Toronto & Muskoka, Canada
