Update: CEL/MIL has not returned in the last 7 days (driven 2x day on 3 occasions), I'll continue to monitor.
Scan below from today, most malfunctions appear to be "body/electrical"
05-Acc/Start Auth. -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: Malfunction 0010
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: Malfunction 0010
5F-Information Electr. -- Status: Malfunction 0010
62-Door, Rear Left -- Status: Sporadic communication error 1000
72-Door, Rear Right -- Status: Malfunction 0010
km/miles from previous scan 9/16 - 301830km-187548miles , so approx 380km/236 miles
Wednesday,25,September,2024,17:18:05:03973
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 24.7.0.0 (x64) HEX-V2 CB: 0.4643.4
Data version: 20240715 DS356.3
www.Ross-Tech.com
VIN: WA1VMBFE9BD004949 License Plate:
Chassis Type: FE-AU56 (4F0)
Scan: 01 02 03 05 08 09 15 16 17 19 28 36 3C 42 46 47 4C 4F 52 55
56 5F 62 69 6C 6D 6F 72 76
VIN: WA1VMBFE9BD004949 Mileage: 302210km-187784miles
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
28-HVAC, Rear -- Status: OK 0000
36-Seat Mem. Drvr -- Status: OK 0000
3C-Lane Change -- Status: OK 0000
4C-Tire Pressure II -- Status: OK 0000
4F-Centr. Electr. II -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: OK 0000
69-Trailer -- Status: OK 0000
6C-Back-up Cam. -- Status: OK 0000
6D-Trunk Elect. -- Status: OK 0000
6F-Centr. Conv. II -- Status: OK 0000
76-Park Assist -- Status: OK 0000
Address 01: Engine (J623-CATA) Labels:. 059-907-401-V2.clb
Part No SW: 4L2 910 401 HW: 4L0 907 401 D
Component: 3.0TDI FSA X18 0009
Revision: 54X18--- Serial number: CVN: 5B6F114CD45710C1D45710C1
Coding: 2A2A4012253600050000
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_ECM30TDI0114L2910401 002008
ROD: EV_ECM30TDI0114L2910401_002.rod
VCID: 619F58C0B1C9525230D-8034
VINID: 9D106675259525250000424424F0AD15F7
No fault code found.
Readiness: 0 0 0 1 X
Address 02: Auto Trans (J217) Labels:| 0C8-927-7XX-V1.clb
Part No SW: 0C8 927 750 S HW: 0C8 927 750 S
Component: AL1000 AISIN 001 3408
Serial number: CVN: 44BD1086
Coding: 001378
Shop #: WSC 29057 003 1048576
ASAM Dataset: EV_TCMAL991031 002112
ROD: EV_TCMAL991031_002_AU56.rod
VCID: 3C21C9B476EB5FBA43B-8068
Address 03: ABS Brakes Labels:. 4L0-910-517-V2.clb
Part No SW: 4L0 910 517 M HW: 4L0 614 517 L
Component: ESP ALLRAD MK25E1 0020
Revision: 00H02001
Coding: 0099473
Shop #: WSC 31414 790 00001
VCID: 3431E194523B97FA8BB-8060
Address 05: Acc/Start Auth. Labels:. 4F0-910-852.clb
Part No SW: 4F0 910 852 B HW: 4F0 905 852 F
Component: FBSAUDIC6 ELV H05 0130
Revision: 00H05000 Serial number: 10602901687210
Coding: 0000135
VCID: 25170CD0E9E1FE720C5-8070
Subsystem 1 - Part No: 4F0 910 132 L
Component: FBSAUDIC6 EZS H03 0020
Subsystem 2 - Part No: 4F0 910 335 B
Component: FBSAUDIC6 KSG H03 0020
Subsystem 3 - Part No: 4F0 910 220 G
Component: FBSAUDIC6 IDG H01 0053
4 Faults Found:
00191 - Passenger's Door Handle Touch Sensor (G416)
007 - Short to Ground
Freeze Frame:
Fault Status: 01110111
Fault Priority: 3
Fault Frequency: 1
Reset counter: 117
Mileage: 301838 km
Time Indication: 0
Date: 2024.09.04
Time: 20:00:36
00193 - Rear Right Door Handle Touch Sensor (G418)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 117
Mileage: 301838 km
Time Indication: 0
Date: 2024.09.04
Time: 20:00:36
00190 - Driver's Door Handle Touch Sensor (G415)
011 - Open Circuit
Freeze Frame:
Fault Status: 01111011
Fault Priority: 3
Fault Frequency: 1
Reset counter: 117
Mileage: 301838 km
Time Indication: 0
Date: 2024.09.04
Time: 20:00:36
01333 - Door Control Module; Rear Left (J388)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 162
Mileage: 301952 km
Time Indication: 0
Date: 2024.09.08
Time: 09:45:36
Address 08: Auto HVAC (J255) Labels: 4L0-910-043.clb
Part No SW: 4L0 910 043 D HW: 4L0 820 043 AF
Component: KLIMA 4 ZONEN H13 0060
Revision: 00---022 Serial number: 00000000255191
Coding: 0004A036
VCID: 25170CD0E5E1FE720C5-8070
Subsystem 1 - Part No SW: 8K0 959 772 D HW: 8K0 959 772
Component: SLR-B8 H05 0006
Serial number: 1002155704
Coding: 070000
Subsystem 2 - Part No SW: 8K0 959 772 D HW: 8K0 959 772
Serial number: 1002156842
Coding: 070000
Address 09: Cent. Elect. Labels: 4F0-910-279.lbl
Part No SW: 4F0 910 279 AG HW: 4F0 907 279 C
Component: ILM Fahrer H29 0390
Revision: 00000000 Serial number: 4F0907279
Coding: 0139123
VCID: 6E8533FC7C97FD2ABDF-803A
Subsystem 1 - Part No: 4L1 910 113 Labels: 1KX-955-119.CLB
Component: Wischer AU716 H12 0080
Coding: 00064792
Shop #: WSC 31414
Subsystem 2 - Part No: 8K0 910 557 Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH04 0003
Coding: 00150059
Shop #: WSC 31414
Address 15: Airbags Labels: 4L0-910-655.clb
Part No SW: 4L0 910 655 A HW: 4L0 959 655 B
Component: 72 AIRBAG AUDI8RH43 0230
Revision: 07H43000 Serial number: 0038QD09L6CC
Coding: 0014130
VCID: 2B03FAE88F05C802DA1-807E
Subsystem 1 - Part No: 4L0 910 339 A
Component: BF-Gewichtsens. H03 0030
Subsystem 2 - Serial number: 6332QSME30781D029
Subsystem 3 - Serial number: 6342QSME0B7A2630F
Subsystem 4 - Serial number: 6352QSME317A31002
Subsystem 5 - Serial number: 6362QSME0B7A002CK
Subsystem 6 - Serial number: 63734SME51720912S
Subsystem 7 - Serial number: 63834SME53720A08.
Address 16: Steering wheel Labels: 4F0-910-549.lbl
Part No SW: 4F0 910 549 A HW: 4F0 953 549 C
Component: J0527 0530
Revision: 00H06000 Serial number: 90025102600144
Coding: 0012242
VCID: 270B06D893EDEC623E9-8072
Subsystem 1 - Part No: XXXXXXXXXXX
Component: E0221 H02 0100
Address 17: Instruments (J285) Labels:. 4L0-920-KOM-V3.clb
Part No SW: 4L0 920 984 A HW: 4L0 920 984 A
Component: KOMBIINSTR. H10 0209
Revision: 00000000 Serial number: FLR4051CA
Coding: 8BD664040900CF05020201
VCID: 313FE880A129A2D2E0D-8064
Address 19: CAN Gateway (J533) Labels:. 4F0-907-468.clb
Part No SW: 4F0 907 468 Q HW: 4F0 907 468 G
Component: GW-BEM 5CAN-M H06 0047
Revision: MB300033 Serial number: 3300M10A01005A
Coding: 00C303
VCID: 3D27C4B06D7156B2745-8068
Subsystem 1 - Part No SW: 8K0 915 181 D HW: 8K0 915 181 D
Component: J367-BDM H07 0125
Serial number: 00000000002790182507
2 Faults Found:
00458 - Control Module for Battery Monitoring (J367)
014 - Defective
Freeze Frame:
Fault Status: 01101110
Fault Priority: 1
Fault Frequency: 1
Reset counter: 117
Mileage: 301838 km
Time Indication: 0
Date: 2024.09.04
Time: 18:55:48
Freeze Frame:
Bin. Bits: 11111
Voltage: 13.40 V
Count: 7
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 162
Mileage: 301952 km
Time Indication: 0
Date: 2024.09.08
Time: 09:45:37
Freeze Frame:
Bin. Bits: 00000
Voltage: 12.30 V
Count: 11
Bin. Bits: 10000
Time: 6.40 s
Address 28: HVAC, Rear Labels: None
Part No SW: 4L0 910 158 HW: 4L0 919 158 AB
Component: KLIMABETAETIGUNGH06 0060
Revision: 00---010 Serial number: 00000000254510
Coding: 0000006
VCID: 688945E45E73231AF73-803C
Address 36: Seat Mem. Drvr (J136) Labels: None
Part No SW: 4F0 959 760 D HW: 4F0 959 760 D
Component: MEM-FS H08 0064
Revision: AA000000 Serial number: 00001002176319
Coding: 00581B00000011110000
VCID: 323DE78CA42F99CA997-8066
Address 3C: Lane Change Labels: None
Part No SW: 4L0 910 566 C HW: 4L0 907 566 B
Component: J0769_SWA_MasterH01 0050
Revision: 00H01000 Serial number: 6PZ 009 014-10
Coding: 0010001
VCID: 2E05F3FCBC17BD2AFDF-807A
Subsystem 1 - Part No: 4L0 910 568 C
Component: J0770_SWA_Slave_H01 0050
Subsystem 2 - Serial number: 6PZ 009 014-30
Subsystem 3 - Serial number: 5F17.10.1000H010003C910698ÿ
Subsystem 4 - Serial number: 910698ÿ
Address 42: Door Elect, Driver (J386) Labels:. 4F0-959-793.clb
Part No SW: 4F0 959 793 T HW: 8K0 959 793 M
Component: TSG FA H12 0361
Revision: Serial number: 0008000091814
Coding: 011F57205E40440004
VCID: 48C9A56432B3031AD73-801C
2 Faults Found:
01705 - Selection Switch for Mirror-Adjust (E48)
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 3
Fault Frequency: 42
Reset counter: 174
Mileage: 301838 km
Time Indication: 0
Date: 2024.09.04
Time: 20:19:12
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 162
Mileage: 301952 km
Time Indication: 0
Date: 2024.09.08
Time: 09:45:36
Address 46: Central Conv. Labels:. 4L0-910-289.lbl
Part No SW: 4L0 910 289 H HW: 4L0 907 289 H
Component: Komfortgeraet H10 0110
Revision: 0110 --- Serial number: 01375589410000
Coding: 3569693
VCID: 3537DC9059418EF2BC5-8060
Subsystem 1 - Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H05 1501
1 Fault Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 2
Reset counter: 162
Mileage: 301952 km
Time Indication: 0
Date: 2024.09.08
Time: 09:45:36
Address 47: Sound System (J525) Labels: None
Part No SW: 4L0 035 223 G HW: 4L0 035 223 G
Component: BOSE G3 Q7 H03 0040
Revision: CH003000 Serial number: 00000000013251
VCID: 26150BDC98E7F56A05F-8072
2 Faults Found:
00870 - Bass Speaker Front Left (R21)
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00111011
Fault Priority: 4
Fault Frequency: 1
Reset counter: 167
Time Indication: 0
03278 - Functionality Limited due to Missing Messages
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 6
Fault Frequency: 7
Reset counter: 174
Mileage: 301861 km
Time Indication: 0
Date: 2024.09.05
Time: 16:48:11
Freeze Frame:
Bin. Bits: 00000001
Address 4C: Tire Pressure II Labels: 4F0-910-274.clb
Part No SW: 4F0 910 274 B HW: 4F0 907 274
Component: J793 RKA+ H03 0110
Revision: 00000276 Serial number: 00002760020873
Coding: 0758477
VCID: 231312C8E7D50042621-8076
Address 4F: Centr. Electr. II Labels: 4F0-910-280.lbl
Part No SW: 4F0 910 280 HW: 4F0 907 280 D
Component: ILM Beifahrer H14 0100
Revision: Serial number: 00000000078845
Coding: 0012001
VCID: 5EE5633C8C376DAA0DF-800A
Address 52: Door Elect, Pass. (J387) Labels:. 4F0-959-792.clb
Part No SW: 4F0 959 792 T HW: 8K0 959 792 M
Component: TSG BF H12 0361
Revision: Serial number: 0008000092077
VCID: 47CBA6583FAD0C62DE9-8012
2 Faults Found:
02126 - Central Locking Button; Exterior Door Handle
Freeze Frame:
Fault Status: 01101000
Fault Priority: 3
Fault Frequency: 5
Reset counter: 133
Mileage: 301838 km
Time Indication: 0
Date: 2024.09.04
Time: 18:55:11
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 162
Mileage: 301952 km
Time Indication: 0
Date: 2024.09.08
Time: 09:45:41
Address 55: Headlight Range Labels: 4F0-910-357.lbl
Part No SW: 4L0 910 357 B HW: 4L0 907 357 B
Component: AFS 1 H01 0010
Revision: 00000001 Serial number:
Coding: 0000031
Subsystem 1 - Part No: 7L6 941 329 A
Component: AFS-Modul links H07 0004
Subsystem 2 - Part No: 7L6 941 329 A
Component: AFS-Modul rechtsH07 0004
Address 56: Radio (R) Labels:. 4F0-035-0xx-56.clb
Part No SW: 4G0 035 082 HW: 4G0 035 082
Component: Radio U SIRIU H51 0052
Revision: AB001007 Serial number: 471J50A7537478
Coding: 020007010000000000
VCID: 5DE764308D3176B2145-8008
Address 5F: Information Electr. (J794) Labels:. 4E0-035-6xx-5F.clb
Part No SW: 4L0 035 664 B HW: 4L0 035 664 A
Component: H-BN-NA H49 0116
Revision: -------- Serial number: 489K00A7541207
Coding: 010200060004E3EF51002305EF6300030000
VCID: 2A0DFFEC8CFFD10A217-807E
Subsystem 1 - Part No: 8R0 060 884 P
Component: NAR 2010 0407
Subsystem 2 - Part No SW: 8F0 919 604 HW: 8F0 919 604
Component: DU7 High H43 0084
Serial number: 9466K%0A0246279
Subsystem 3 - Part No SW: 4L0 910 609 HW: 4L0 919 611 C
Component: E0380 Bedient H05 0060
Serial number: 00000001714827
Subsystem 4 - Part No: 8R0 060 961
Component: CD-Database 1886
1 Fault Found:
03157 - Functionality limited due to Communications Disruption
Freeze Frame:
Fault Priority: 6
Fault Frequency: 16
Reset counter: 176
Mileage: 302192 km
Time Indication: 0
Date: 2024.09.25
Time: 16:41:44
Freeze Frame:
Bin. Bits: 00000000 00000000
Bin. Bits: 00000100 00000000
Address 62: Door, Rear Left (J388) Labels:. 4F0-959-795.clb
Part No SW: 4F0 959 795 P HW: 4F0 959 795 P
Component: TSG HL H11 0361
Revision: Serial number: 0008000090652
Coding: 010E57204040230004
VCID: 46D5AB5C38A7156A25F-8012
Address 69: Trailer (J345) Labels:. 4E0-907-383.clb
Part No SW: 4E0 907 383 J HW: 4E0 907 383 J
Component: Anhaenger H08 0100
Revision: 2A001001 Serial number: 00000136903522
Coding: 0200000000000000
Address 6C: Back-up Cam. Labels: 4L0-910-441.clb
Part No SW: 4L0 910 441 B HW: 4L0 907 441 B
Component: J772__Rearview 0030
Revision: --H04--- Serial number: 525PA8-J0X40F9
Coding: 1021201
Address 6D: Trunk Elect. Labels: 4L0-910-945.clb
Part No SW: 4L0 910 945 HW: 4L0 827 851 E
Component: ValeoHeckdeckel H55 0500
Revision: --H55001 Serial number: E5030000B
Shop #: WSC 98765 666 38354
VCID: 6C8139F44A8B0F3A93B-8038
Subsystem 1 - Part No: 4L0 910 946
Subsystem 2 - Serial number: E5030100B
Subsystem 3 - Serial number: RD04.11.10--H55001001B0107ÿ
Subsystem 4 - Serial number: 1B0107ÿ
Address 6F: Centr. Conv. II Labels:. 4L0-910-290.lbl
Part No SW: 4L0 910 290 A HW: 4L0 907 290 A
Component: ILM HINTEN 2 H05 0070
Revision: AAH05061 Serial number: 109570365-----
Coding: 0003595
VCID: 26150BDC94E7F56A05F-8072
Subsystem 1 - Part No: 4L0 910 591 A
Component: J_245_EE16_SKB10H11 0220
Subsystem 2 - Part No: 4L0 910 591 A
Component: J_394_EE16_SKB10H11 0220
Subsystem 3 - Part No: 4L0 910 591 A
Component: J_392_EE16_SKB10H11 0220
Address 72: Door, Rear Right (J389) Labels:. 4F0-959-795.clb
Component: TSG HR H11 0361
Revision: Serial number: 0008000087597
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 117
Mileage: 301838 km
Time Indication: 0
Date: 2024.09.04
Time: 18:55:10
Address 76: Park Assist Labels: 4Fx-910-283.lbl
Part No SW: 4L0 910 283 C HW: 4L0 919 283 C
Component: Parkhilfe 8-Kan H03 0500
Revision: 00H03000 Serial number: 37331029520823
Coding: 0231266
VCID: 2A0DFFEC80FFD10A217-807E
End----------(Elapsed Time: 02:23, VBatt start/end: 12.5V/12.4V)-----------
