farnhamassoc
- Joined
- Jul 9, 2011
- Location
- Riverside CA
- TDI
- 06 Jetta tdi, 09 TDI SPORTWAGEN 2011 Audi a3 TDI. VW caddy turbo diesel... Various vw split window busses
Well I replaced it and it is still not right but for some reason it is Better? IDK I can actually drive it now. Last night before I changed it I had to stop every mile or so turn off the engine then restart because it just would not go anywhere. Now feather the gas and your off to the races. just about every light I need to do it but sometimes it just goes. I do have another issue.....Trans clutches. Were not going there right now. Might be getting an F U signal from the trans. when I hit the gas then the second or 3rd time it decides its ok I will let you have boost. IDK.
I had code I think it was p2711 implausible gear shift disengagement....2 years ago I could not find any information of what that is. Now I know it is clutches. Searched it and nada. Now it is everywhere.
I had that code but drove it for 2 years like that just babied the clutches. while driving there was no issues. just when I came up to a light it would click then I would let off the brake and reapply to keep it from going into trans limp PRNDS flashing. Worked like a champ.
The reason I wanted to put in a USED engine and trans was because I was on the freeway when the oil pump hex shaft went bad. Got right over but I really was not sure about the bottom end. or any of the internal engine parts. I removed the pan and put a new shaft in as a temporary repair. Just to see. No grey or silver in the oil. But the turbo was noisy after I restarted it.
So I was going to Can the car because the engine and trans both had expensive issues. Then I saw a wrecked car with an engine and trans with 86k miles on facebook marketplace. I asked the guy how much for the complete engne and trans with turbo. 1200.... so I figured this would be cost effective to do since I had done the emissions scandal and had no codes other than the trans which I was swapping.
Didnt work out that way......Trans was trash all the plastic parts were malted lava in the bottom of it.....NO signs of any of that from the outside. Turbo was tight but vanes were stuck (replaced with my old one new total rebuild with new professionally balanced high quality cartridge), alternator trash, almost every part that was on the engine was bad. I was just getting ready to do the timing belt and CP3 conversion before this happened. So I had a full German kit. One at a time I had to replace the parts with my old parts or buy new ones. The first clue was every pan bolt was hand tight....When I did the oil pump upgrade I found that out. Valve cover bolts were loose. None of which I knew until after I put the engine in the car. When I got the first clue I decided to go CHEAP on the trans clutches. because I didnt want to spend so all this money on a motor that was junk. After I did lots more work to it I realized the engine was low miles. Just sat for a long time before I got it and they knew that trans was bad. A H's
Well anyway there is much more to this story but FYI. I Never usually buy cheap parts. Only OEM or German. Other than the CP3 which that guy has sold tons of them and I have not heard anything bad about those....His other parts IDK....
So anyway Trans wont adapt. Computer does not like the Transpeed clutches. Shifts like crap and I think that might be effecting the drivability now.
