farnhamassoc
- Joined
- Jul 9, 2011
- Location
- Riverside CA
- TDI
- 06 Jetta tdi, 09 TDI SPORTWAGEN 2011 Audi a3 TDI. VW caddy turbo diesel... Various vw split window busses
Ok Here is the most of it.
I had the oil pump hex shaft fail replaced the engine with another used engine. Coded the injectors to the engine, Adapted the EGR, Also installed a CP3 pump. Deleted the 2nd fuel pump (required for CP3) Adapted the exhaust pressure valve. (broke that on installation)) Most parts came from old engine with no codes.
Here is the problem When I just out of the box floor it it codes po299. Idles and runs fine. when in neutral or park revs up to 2500rpm then that is it. When I feather the gas pedal for instance hit the gas a little about 3 times it ramps up some serious boot and burns the tires. New turbo had new cartridge done by professional shop. Veins working perfectly and freely. I installed the VNT and adjusted it as follows used a mighty vac and between 3 and 5 inches (just starts to move) put that at the top. when it is at 15 to 20 it is fully open (down) from what I can tell. When I run the engine at stand still revving the engine the actual and projected( whatever its called on the RossTech) boost pretty much match on the graph. If I feather the gas pedal It does not seem to code. just really hard to drive.
Any ideas.
Mike
Any ideas.
Mike
