Dually
2012 audi a3 150k miles. I've had this hot start problem for a few years that's only gotten worse.
Cold start is fine. Just a revolution or 2 and it runs fine.
Hot start is a couple revolutions, stumble and stall. Repeat that a few times and it will eventually stay running and run great.
It's been to a couple generic diesel mechanics and none see a problem. I've called specialists within a 2 hour radius and nobody wants to look at it.
Injector deviation seems fine. Never more than 0.3 hot or cold.
Regens are normal.
Pressure differential is 8 at idle.
If the specs in obd eleven are correct, everything is within spec.
Battery is new.
Starter was replaced while out of town with unknown brand
It's hard to get engine speed data on vcds when I have to turn key off and restart. By ear it's spinning slower when cold and starts fine. The odd thing about all this is after a timing belt change, it was starting fine everytime for a few days.
Darkside has a tune for this issue but before I go that route. There must be some underlying cause and tuning seems like a bandaid. I'd like to know what is actually happening to cause this and fix it correctly.
Regens are normal.
Battery is new.
