Catless downpipe
Mk3_Moe
Sacramento
1998 Mk3 TDI AHU
Hello!
Does anyone know any websites that make catless downpipes for ahu tdi’s because I’ve been trying to look around and couldn’t find anything.
Mongler98
Northern MD (HAGERBUSH)
yes, many of them
Darkside
Kerma
literally any decent muffler shop can make you whatever you want.
Your in CA so its extremely unlikely your going to get any of that though.
Mk3_Moe
Sacramento
1998 Mk3 TDI AHU
yes, many of them
Darkside
Kerma
yep, unfortunately Cali is like that but the muffler shops usually don't have any restrictions to what you want, im guessing they range from $150-$300 on kerma and darkside? ill check it out
Mongler98
LOL try again, 300? i WISH
most of these down pipes are in the 800 to a grand range.
want one cheap, learn to weld!
Mk3_Moe
Sacramento
1998 Mk3 TDI AHU
on darkside i found the downpipe for 200 pounds which is a lot in usd haha, I could not find it on kerma for some reason.
Mongler98
OH, for some reason im thinking back to the thread about DPF deletes...... yea down pipes are not too bad in $, my mistake, not sure what i was thinking.
Mk3_Moe
Sacramento
1998 Mk3 TDI AHU
no worries, it took me a while to try and find them but i had to ask forums to make it easier for my self. my ahu just hit 222400. running strong i have a muffler and res. delete and there is no noise difference which kind of sucked when i did the delete but i am definitely getting more coal out tho not a lot just the perfect amount and slightly better throttle response
Mk3_Moe
Sacramento
1998 Mk3 TDI AHU
This will fit the following vehicles with the engine codes listed below:
VW Golf Mk2 - 1Z / AHH / AHU 90
VW Golf Cabriolet - 1Z / AHH / AHU 90
VW Golf Mk3 - 1Z / AHH / AHU / ALE 90
I think it also says vento and then the ahh 1z and the AHU engine code so I’m guessing I’ll be good with buying that one right?
