Car won't turn over ... what did I do?
mk4mr
Mid Tenn.
1999 Jetta TDI
Hello to all. I have an odd situation that has developed with my 99' tdi Jetta this evening. Within the last month or so, I tagged and insured this car and have been driving it everywhere with no issues whatsoever. I have had a pesky, flashing glowplug light since I got the car, and I was working on that today. I had a blown brake light and both of the marker lights in the sides of the front fascia were blown as well. I replaced all three bulbs with new ones and while I was in the trunk, I removed the non-working factory cd changer to see if I could tell what was wrong with it.(Will not eject...will not do anything, as if it has no power). Anyway, I put the cd changer back in place when I was done. I didn't do any other work to the car. When I was finished, I thought I'd start the car to see if the glowplug light was gone. When I put the key in the ignition and turned it to the 'on' position, the radio came on as well as the dash/gauges as they would do normally. When I turned the key to 'start', I got absolutely nothing. There were absolutely no clicks or sounds of any sort. I had just driven that car a couple of hours or so before. I have had zero issues with this car as far as the starter engaging. I have not had time to look at the fuses inside the car. I did look at the ones on top of the battery and they look ok. I have not had time for any meter checks.
Here's one thing I'm wondering ...
When I put the cd changer back in place, I was carrying it and my 18v cordless drill and a couple of things in my arms, as well as the car's flip key. When I was putting all of these items in the trunk of the car to re-install the cd player, I noticed that the key ring on the flip key was 'stuck' to the magnet on the drill base. I'm wondering if the battery on the base of the drill wiped the chip in the key fob. I don't know how the immobilizer works on the 99.5 Jettas. If the chip goes bad, will it let the starter engage? I have dealt with immobilizers on 01' and higher, but I believe they are different. Have I wiped the information off of the chip with the magnet or have I possibly blown a fuse somehow?
One other thing I did notice while in the trunk. The courtesy light that mounts above the compartment where the cd changer is stored was hanging down due to a broken tab. In an attempt to get it out of the way, I tried to stuff it back into it's place and it went out. I pulled the bulb and it looked fine but I could not ever get it to light up again. I don't know if I might have shorted something in this circuit that would prevent the car from allowing the starter to engage. I don't think there is anything wrong with the starter, I just think it's being held out due to something I've done. If it's not raining tomorrow afternoon I'll do some meter checks.
What do you all think? Any suggestions? Thanks for any ideas!
jettawreck
Northern Minnesota-55744
2001 Jetta and 2003 Jetta
Not unusual for the large cable from battery to starter to corrode and finally burn off. Depending on the location of the burn off of the wire it may require a new starter unless you have a good friend that rebuilds them and can replace the connection and/or get the part.
Been thru this situation, but usually it happens in a inconvienient location or as you are ready to leave for work or an important appointment.
Generally if it's an immobilizer issue the car will crank and start/shut down.
It's not really a "chip" in the key blade. There is a tiny glass "tube" with a radio crystal in it located in the top of the fob.
csstevej
north nj
2001 golf tdi 4 door auto now a manual, mine, 2000 golf 2 door M/T son's,daughters 98 NB non-TDI 2.0, 2003 TDI NB for next daughter, head repaired and on road,glutton for punishment got another tdi 2001NB,another yellow tdi NB , added an 06 NB DSG
Could also be a bad ignition switch.
Also the switch on the clutch pedal for starting.
gforce1108
Newburgh, NY
04 Jetta GLS BEW, 14 Audi A7 V6 TDI, 13 Porsche Cayenne V6 TDI
No immobilizer on a '99.5 Jetta.
Even if there was, it'd still crank over - start and then shut off.
If only I had one. The car only came with one key when I bought it. Surely this is a fuse issue.
If I remember correctly - the early cars without the immobilizer will not crank when the alarm is active. I've seen people disconnect the alarm so it doesn't beep, but is still active. Typically locking and unlocking will clear it (I have had a 99.5 that would only work if you disconnected the battery, turned the ignition to run, and reconnected the battery - it had several "issues" with the door lock modules).
mk4mr
Mid Tenn.
1999 Jetta TDI
Well, as it turns out, it was fuse 14.(interior lights/central locking system). I suppose that the courtesy light inside the trunk shorted when I was fiddling with it and blew the fuse. I don't know why those two circuits are tied together like that, but they are.
A couple of statements ...
The early models do indeed have some form of security feature that will not allow the car to even try to start if someone tries to steal your trunk mounted courtesy light. ;) I don't know if mine is acting totally correctly, as there is no obnoxious beeping of the horn like my 2000 beetle does, but I'm here to let you know that it will definitely refuse to crank if the security 'feature' is triggered. --Also, the key would not unlock the trunk although it would unlock the door. Unlocking didn't help, but the fuse was blown, so otherwise, maybe it would have. IDK...
Thanks to everyone. I hope something here will help someone along the way. I'm just glad my car started back and that my only key is not messed up.
mk4mr
Mid Tenn.
1999 Jetta TDI
Thanks for posting the resolution to the issue. Helps everyone when we do that.
Thanks for the 'boost'! If I only had a nickel for every time I'd searched a particular subject/problem only to never see the final prognosis revealed. I'm learning as I go, but I always try to make sure my posts are closed, if indeed they are ever closed. :)
