BobnOH
not-a-mechanic
Relay 109 provides power to the ECU, so it can cause no short list of issues.
the BEW has no injector lines and no way to bleed the system... ubless tehre is a way but i have no clueI'm not sure about your year, but on mine I had to loosen all the fuel lines from the injectors and turn the car over until all the air was purged and diesel was coming out. Once I did that it fired up.
i tried that aswell.....How about adjusting the injector lash?
Jason
where should i be looking, for wiringDont know for sure, but I think you would have to really screw up to get all four injectors to not work at all. My bet is electrical so check the wiring.
what should i google to find info on the plug in for the two wires that run onto each injectorwhere should i be looking, for wiring
Injector lash before or after it didn't start?i tried that aswell.....
i did the lash after it did not start.... also i just called a tdi performance place out of calgary, and the guy said that the injectors should not be the problem and that he believes its an electrical issue...Injector lash before or after it didn't start?
The harness that lives in the cylinder head can get brittle. Thou I'm sure there are a few other places that could also be a problem with age/miles.
I'm curious how you did the nozzles. When I had my BEW Golf I played with the idea, but decided against doing it myself as they are much more involved to change than the ALH. Possibly something got FUBAR inside the injectors?
Jason
Problem is you can destroy an injector by not having the lash set correctly. The lash adjustment sets the plunge depth of the injector. If you have it "too tight" then the rocket pushes down too far on the injector cause internal parts to smash together and break.i did the lash after it did not start.... also i just called a tdi performance place out of calgary, and the guy said that the injectors should not be the problem and that he believes its an electrical issue...
and to do those nozzzles is actually super easy... u take the o rings off and than un due the cone of the injector and pop the nozzle out from the cone and slide the new one in..
but i am definitly going to look at that harness. what all can i do to test tthe injector harness? and where else should i be looking aswell?
We need more info....Hey so mine cranks wont start if i unplug crank sensor it starts reconnect and doesnt start a hose clamp slapped the timing plastic cover cause little piece of 2 to go and fall towards the inside timing area, no codes anh help? Would a piece cause not to start
when i was tying to finish hooking up the clamps right after undoing them, i am pretty sure it was right after i moved the car like a 100 feet, i turned it off and kept trying to the clamp by the time cover a bunch of failed attempts simletounausly crsckimg the cover the clampunlesshed on it multiple times is that a big problem do you know how much it will cost i hope i didn't do further damage, you think it still logged in there somewhere or like you said it might have humped a toothWe need more info....
So, when did the "piece" fall into the Timing Belt area?
There is a possibility the piece of plastic ended up causing the belt to jump one tooth.
Ok so you think its a humped toothdude - punctuation so we can follow your thought process.
Now I really want to see what a humped tooth looks like
If one of the spring clips pops off the pliers there's enough force to strike a spark just by hitting a metal part. I have seen that on the bigger clamps.
Jason
This issue was finally fixed with a new mass airflow and ip was so retarded it didn't show on the graph.2001 Jetta won't start SOMETIMES.
Good evening all, I'm new to this forum and new to the TDI world. Having starting issues with a 2001 Jetta sometimes. The car has 184000 miles, timing belt replaced at 110000 miles. The injection pump was recently replaced with a remanufactured pump. The car starts good normally. The issue seems to be after the car is parked for an hour or so. The engine is warm enough that the glow plug light only comes on for about a second. Start cranking and it will fire die fire die, give it some throttle and keep cranking it will eventually try to run without the starter cranking. I then hold it to the floor while it rattles and bangs, blowing white/blue smoke like crazy. It eventually clears out ( or dies, then you start over ) and runs fine. Seems to start fine after being shut off for 15/20 minutes, or the next morning or after work. When it has this issue it reminds me of a flooded gasser. Any help would be greatly appreciated.
So, engine ECU add a immobilizer error, which was cleared. This allowed me to reset the immobilizer using the connect the two battery terminals together method. Still will not start, no other errors in my friends ECU softwareOld thread I know but I have issue number 5. 1.9 TDI 90 BHP Auto
The car has been stood for 2 years. The auxiliary belt came off and had to get towed home. Somehow the starter motor got jammed so this was changed with the belt and belt tensioner.
The car turns over fine, all lights are on yet does not start. There is ample fuel at the ejectors (I took each one off and attached a rubber tube to it and a bottle, plenty of flow) and the have checked the air valve that gets stuck closed and this is open. I have tried making small adjustments to the timing belt to no avail. Electricity, I have followed everything in relation to post 5 with no luck.
Is there anything I am missing?
