windmillag
A little help please...
Turbo seems to work fine good air coming in, good flow out, feels tight, no slop. Even checked exhaust pipe, has a nice flow, also. Also, went out this morning with the valet key, effects are same a with regular key. I get the immobilizer icon when I try to start with the valet key and not when I use the intended key, but the action/reaction is the same, but no warning light flashes. This seems to rule out the immobilizer circuit but it is acting just like that. I've tried resetting the key by 10-20 min turned on, with charger hooked up, then attempting to start again, also disconnecting battery and holding together cables, 5-10 min, but both of these methods have failed. I'm inclined to think the ECU is good since it does fire up and run, albeit for a very short time. Do you have another idea to try? Thanks, Aaron
