whitedog
Please note that this is a work in progress. If you can help fill in the blanks that I note, please PM me or post here.
Thank you.
So, your car will not start. This is probably the second most common problem discussed on TDI club, second only to glow plug problems. I will try to outline some of the problems that people have had, provide links to what has been done and add some pictures and links to guide you along to get your car started.
If it's cold and you have a 2009-2012 Jetta CLICK HERE for information.
"Legal" stuff:
If you have a "No Start Condition" (NSC) you need to differentiate between some different fault situations.
The Mixed Bag: Maybe you find that you have a little bit of this and little bit of that: If that is the case, do the troubleshooting for both.
Don’t crank the engine over for more than 30 seconds at a time, then allow at least two minutes of cool down before you crank again. This is to protect the starter from overheating, exacerbating your situation such as in this post
If you have any tuning boxes on your car, remove them and see what happens. Your box may be causing a problem.
Glow plugs only help the engine start, they are not required until the temperature gets very cold. (Very cold is described as when you breath and your nose hairs freeze)
Finally, if you are having electrical problems check the fuses first then check the grounds on the car. Even if things don't seem related, make sure all of the fuses are good.
Does your car start, but won't shut off? Unplug your fan control module and see if that takes care of the problem. See HERE for a thread with this problem.
A few definitions as they relate to starting the car.
I'm going to put each of these in a different post, so if people have additional information, quote the pertinent post and I'll try to add your information in that post, or at least link it there.
The basics.
First, here is a post with much of the basics of the diesel engine.
For the TDI to start, electrical power needs to flow from the battery through fuses and relays to the key switch and ECU. From the key switch, power needs to flow through more fuses and relays to the start solenoid on the starter and from the ECU power needs to flow to the injection pump.
For the TDI engine to run, it needs three things: Sufficient air, sufficient fuel injected at the
correct time and sufficient heat generated by compressing the air.
HERE IS A LINK to the TDI FAQs about no starting. Much of it is the same as what is found here but here you have pictures with circles and arrows and a paragraph explaining what each one is about.
HERE IS A LINK to the basic starting system for >2000 J/G/B. HERE is the list with reference numbers for what stuff is and where most of it's located. Stay tuned for updates.
Thanks to Fred
Without Fred and this forum none of this information sharing would be possible. If this thread was helpful and you saved mega bucks fixing or diagnosing the problem yourself, please consider a donation (see paypal button on home page) to ensure that this site remains available in the future.
Thanks to all of TDI Club
Without the members of TDI this thread would not exist. The only thing I have done here is assemble the collective information of others. They are the heros for putting the information out there for everyone.
Thank you.
"Legal" stuff:
- This is by no means a comprehensive list of problems, just some of the most common.
- Use common sense when doing any testing and be sure that you won't get run over if the car suddenly and unexpectedly springs to life.
- I don't want to confuse anyone if a fuse, switch or relay is in a different position on different models or model years, so the location may vary from what I give. Hopefully people will be able to add different information as it becomes needed.
- Everything here assumes that the engine started fine and ran fine earlier, but now it suddenly won't start.
- This does not include "hard starting" which is detailed elsewhere.
- <2003 means "2003 and earlier", >2004 means "2004 and later".
- I have not looked into stuff specific to the A3 cars. Some of this stuff is basic stuff that applies to all cars, but I have nothing specific to the A3s yet.
- You were driving along in your car and the engine died and won't start, or it just won't start, but may start after sitting for awhile.
- You were driving along in your >2004 car and the engine died or you just changed the fuel filter and won't restart or restarts and runs poorly.
- You turn the key to start and nothing happens. You don't get any lights, beeps, buzzing, clicking or noises from the engine compartment.
- You turn the key to start and you get some of the lights, beeps buzzing or whatever, but no noises coming from the engine compartment.
- You turn the key to start and you get the lights, etc AND the engine turns over at normal speed but it does not fire.
- The engine turns slowly and doesn't start.
- You turn the key to start and you get the lights, the engine turns over and FIRES! then it dies after running for about two seconds.
- You just replaced the timing belt and now it won't start.
- You just had something in the fuel system open or ran out of fuel and now it won't start.
- You have a DSG transmission, and when it's really cold out, the car won't start.
- You have a >2004 and nothing else here fits but it could be fuel related.
- Here are some miscellaneous links to some oddball no starts that don't quite fit.
A few last general notes:
- Key On: This is the position of the key when the engine is running.
- Start position: This is with the key turned to where the engine should be starting.
- Cranking (or turning over): This is when the engine is rotating. Look at the alternator belt to see if the engine is cranking if you are unsure.
- Start(ing) or fire(ing): This is when there is combustion and the engine is trying to run or is actually running.
- ECU: Engine Control Unit; the computer that controls the engine.
The basics.
Thanks to Fred
