Car wont start, battery reads 12.9v
offthewall
Oregon
2013Jetta
Car wont start, a couple days ago leaving familys the car was dead. Headlights were left on and a door open. Jumped it and it started right up, drove it home and everything was fine. Restarted fine. Couple days later went to take it and it just clicks. Put a battery charger on it for a few hours until the battery was reading in the 13s. Car still only started when I put the battery charger on the jump start setting. Drove the car around fine, restarted after sitting for 15 mins. Left it for a couple hours and checked the voltage at 12.9 and it wont start, just clicks. Sounds like a relay clicking, not the starter. Left it on the charger over night and still same thing with voltage in the high 12s.
Is there a relay that can go bad? Seems that the battery being in the 12 volt range it should have enough juice to start.
Thanks for any advice
Nughuffer
Middle TN
2012 Jetta TDI; 93 W250 12V CTD
Sounds like you have voltage but no current (CCA). Have the battery tested. Id be willing to bet you have a dead cell.
offthewall
Oregon
2013Jetta
ok thanks, been doing alot of reading about batteries on here and everyone says to go with a OEM battery, any reason not to do an optima red top?
whitedog
Bend, Oregon
To test that battery, charge it, then put your multimeter across the battery. Then try to start the car. I'm betting that you will see the voltage drop way under 7 volts when you try to start the engine.
I just paid $120 for a new battery for my Jetta. Well, actually it was for my Audi, but it takes the same battery.
scdevon
USA
None
Yep. Current is what starts the car. Not voltage.
Actually proper voltage at the proper current is what starts the car.
A 12.xx whatever voltage surface charge means next to nothing.
