Brianne5speed
Hi guys and gals,
I have a 2006 jetta tdi which I've really had no problems with until now.
Just replaced the battery, the old one was leaking apparently. 150 later, still have the same problem.
It thinks the drivers door is open. All dome lights on. Beeping warning for door not closed though it absolutely is. Window switch was replaced a few months ago with no issues. Now the entire drivers side door controls don't work unless open a certain amount. Son and my dad pulled the fuse for the upper dome lights. But under dash lights still on. Ugh. Can't afford a huge fix so I'm hoping and praying that maybe one of you had this problem and it was not a huge cost to fix. Thank you for your time
