Jaxon
- Joined
- Jan 15, 2006
- Location
- Saskatchewan, Canada
I have a 2012 Sportwagen TDI that has been giving me intermittent starting issues since I bought it two years and 50,000 k ago. It's gotten progressively worse.
Here's what I've narrowed it down to - when I start the car in my garage in the morning it's +5 celsius - car usually starts right up, does it's usual couple stumbles, and I'm on my way. I park in a heated parkade where at the end of the day and I go to leave it's +22. The car refuses to start, I need to spin the motor for about 30 seconds (usually pause 5 times) then I get a huge cloud of smoke, stumbles for 10 seconds, then away I go. It is even worse in the summer as the car sits outside then where it could be 15 - 30 C. The car starts perfectly once it's been running and only acts up again once the engine has cooled off.
Here's what I know:
- Not intercooler icing, I've checked it twice, once in the summer and once in the winter - only a few drops came out. In the winter the car starts and ends its day in a heated garage, and has a 15 mile commute each way;
- The car was parked for 2 months, it was +10C out, I connected the battery and it started right up, so I don't think fuel could be draining back;
- Fuel filter has been changed every two oil changes, and the condition has never improved after a fresh filter;
- Just swapped to a CP3 pump, didn't help;
- Malone stage 2 delete tune, EGR disabled, did not help;
- Changed the fuel return line & valve on the injectors, didn't help;
- No codes;
- Changed glow plugs with known good parts from my parts car, didn't help;
- I've unplugged the ASV and it didn't help;
- All maintenance is up to date on the car;
- Battery is new, and is the second new one in six months.
So is there something that regulates how the car starts based on ambient temperature? Last winter I parked outside, and even in -30 C it would fire right up (plugged in). Yet all summer it started really badly. And I know that it has to do with ambient temperature due to the temperature differences in the two garages. I do have VCDS. Thoughts? Can someone help me out here? I've searched tonnes of threads but nothing similar!
Here's what I know:
- No codes;
