perrya
After sitting overnight, a cold start will fail because it starts and dies fast unless I pump fuel. Once started, it runs fine and starts right up even if parked for hours. If I fail to start it, it will take about 3-4 tries and then it will start once pressure is built up. I suspect a bad injector at 225K. Tandem pump, fuel pump, glow plugs all are fairly new. There is no lack of power, no codes. Still gets great MPG.
Is it an injector pressure related issue? something else? vacuum leak?
