My bug doesn't warm up at all going to work. It's all city driving, stop and go. The air temps are between 0-10 F. My dealership told me there are no block heaters or masks. What can a gal do to warm up toes? Thank heavens for seat heaters....
Wool socks are a good idea. So is something to block airflow into the engine compartment. Your dealership doesn't sell anything that will help you, that doesn't mean there aren't remedies. Also, turn the heat control knob all the way to HOT, not just part of the way.blubug06 said:My bug doesn't warm up at all going to work. It's all city driving, stop and go. The air temps are between 0-10 F. My dealership told me there are no block heaters or masks. What can a gal do to warm up toes? Thank heavens for seat heaters....
You've got other issues, at highway speeds it should reach 190*F on the gauge (which is really 160*F to 215*F+) in 10 minutes or less.tdenhartigh said:Anyone know where I could get a winter front for a 98 Jetta? I can't find anything at Impex.
I have a similar situation...even on the highway in the winter I can't get the engine temp up to normal (190 deg).
If you want to heat the air to get rid of condensation, doesn't it make sense to get the cabin warm as soon as possible?weedeater said:With recirc, you will have frost/fog problems. Just be aware.
It depends on the weather conditions. In many situations you just can't use recirculate and expect not to have fogged windows.whitedog said:If you want to heat the air to get rid of condensation, doesn't it make sense to get the cabin warm as soon as possible?
Right, you have to remove the moisture. That means opening a window a bit or driving so that the natural venting of the cabin will exhaust the air out.Joe_Meehan said:It depends on the weather conditions. In many situations you just can't use recirculate and expect not to have fogged windows.
Heating air does not REMOVE moisture it reduces humidity. The windows will still be cold, even in a warm car and you and passengers will be adding moisture as you breath. That moisture is going to end up on the windows as condensation.
It usually is better to use fresh air.
dittotexascadillac42 said:Another vote for the Frost heater. Quick and easy install, nice unit, and cheap. By far the best $100 ive spent on the car so far. Instant heat upon startup.
I'm about ready to buy one of these http://www.floormat.com/heated-car-mat.html 'cause even with highway driving the air that blows out is warm but nowhere near hot- and that's on recirc! Take it off recirc and it's actually COLD. I'm suspecting a damper is hung up allowing outside air to blow through all the time, but haven't had time to take stuff apart to see if my suspicions are fact. And yes, thank heavens for seat heaters. Car engineers should spend more design time on heating feet and legs. Directing all the flow to defrost and nothing to feet isblubug06 said:My bug doesn't warm up at all going to work. It's all city driving, stop and go. The air temps are between 0-10 F. My dealership told me there are no block heaters or masks. What can a gal do to warm up toes? Thank heavens for seat heaters....
Just what is the deal with the air selector (defrost, floor, panel, floor and panel)? Is there some German law that requires defrost to shut off the recirc and not blow air anywhere but on the windshield? This is probably the single most annoying part of my VW.RT1 said:Car engineers should spend more design time on heating feet and legs. Directing all the flow to defrost and nothing to feet is
crazy for winter driving.
Do you want moist air blowing on your cold windshield?MCR said:Just what is the deal with the air selector (defrost, floor, panel, floor and panel)? Is there some German law that requires defrost to shut off the recirc and not blow air anywhere but on the windshield? This is probably the single most annoying part of my VW.
I have been experimenting with putting the selector 45 degrees left from defrost. It blows from all three locations, possibly favoring the floor, but I'm not sure it blows as well as on one of the four detents.
I just found a ZeroStart 1000W for $38. Hopefully I can get it installed this week.
