Hey guys, long time no post,
Anyways, my '02 golf with 220k miles on it has started acting up.
It throws a MAF code.
It has no power AT ALL, until I exceed some certain RPM and the default MAF values kick in. Then its driveable, but only just. I am not comfortable driving on the highway at either power level, default MAF values or not.
The only reason I don't think it is the MAF itself is that this pretty much happened over night. AFAIK, MAF failures happen gradually?
Here's some things that I've done in no particular order.
So my first question is what have I missed?
Secondly, should I see continuity between MAF connector pin #3 and chassis ground? I feel like this could be my issue.
What else can I do to troubleshoot before throwing $115 at it in the form of a new MAF?
Thanks for all the help guys!
- Scanned car for codes, Only thing I have is a MAF error.
- Tried logging specified vs actual MAF but it just defaults to 550 or whatever so the logs are useless.
- my boost target is 23psi but I can only get to about 18 psi or so.
- Checked turbo actuator, feels fine, vacuum lines all connected and dont appear leaky or damaged
- When I have the ignition on but the car not running, MAF actual is 1275mg/stroke and when i start the car and idle this falls to either 10 or 5. Then upon revving the car this falls to 0mg/stroke assuming I dont exceed some RPM that kicks it over to the default values.
- I cleaned the MAF element with no change
- According to MyTurboDiesel, the MAF conector pin #2 should be 12V, which it is.
- MAF connector pin #3 should be ground... I see 12V across pin #2 and #3, but i DONT see continuity between pin #3 and the negative battery terminal OR ecu pin #4. I'm suspicious of this but if this is wrong, then why am I seeing 12V across this ground??
- MAF connector pin #4 should be 5V, which it is, right on the nose.
- I took off the ECU connector and according to MyTurboDiesel, MAF pin 3 should be connected to ecu pin 4, MAF pin 4 should be ecu pin 50 and MAF pin 5 should be ecu pin 52. Although I did find pins on the ecu that were connected to MAF pins 4 and 5, they weren't pins 50 and 52. I cant remember what they were, but the fact that i did find 2 pins that were connected made me feel like that was OK.
- I also nicked each wire coming from the MAF with a razor blade to be sure that the wire itself was connected to the pins in the MAF connector, which they all are. I've heard of the MAF connector failing or becoming oxidized but this doesn't seem to be the case.
- IQ is at 6.5, I don't think this is relevant but I checked it while I was in there with the VCDS.
