oneshort
- Joined
- Feb 12, 2004
- Location
- South of Chicago
- TDI
- (his)Beetle, 00, blue w/ wht & purple flames... ((his)Beetle, 00, blue w/ wht & purple flames... (hers):Beetle, Yellow with bra and daisy lights...
2000 NB with manual transmission, 170,000 miles. Suddenly I can't shift gears while the engine is running. I tried a Spindown test (clutch in, wait, shift into reverse) and the gears clash like I didn't have the clutch pedal all the way down. If I start in first gear, the car tries to roll forward slightly with the clutch to the floor. The brake fluid resevoir is filled completely- no obvious signs of brakefluid leaks. The transmission has never slipped.
Are there any adjustments that can be made at the pedal or master cylinder? Any guesses at what might be the cause? I'd expect a worn clutch to slip, or am I wrong?
