Canola oil as fuel additive?
dweisel
Wheeling, West Virginia
dweisel isn't diesel anymore!
Ah, I never threw it back in their face,but you are correct about the parroting misinformation. Plus it was a member with forum clout here.
BioDiesel'
CT
1998 Jetta Elsbett single-tank, 230K WVO miles
RE: 12 year old thread is apt for my 12 year old SVO conversion
Been averaging 80% WVO or SVO, canola, soy, corn, peanut. 238,000 miles so far.And NONE of the calamities claimed by a few of the 'knowledgeable' posters to this thread. :D
I'll try to add some real knowledge.
University study of SVO use in an unconverted DI @ 25% SVO:
http://www.regional.org.au/au/gcirc/6/214.htm
Mr. Flibble
Issaquah WA
2013 Sportwagen Manual, Sunroof/1995 Mitsubishi Delica L400
Are you heating it prior to burn? Reason I ask is that you seem to be from Connecticut, and the guys I know that run on WVO pre-heat their oil before the switch - in the summer you can run 50% or greater with ease, but not so in the winter.
BioDiesel'
CT
yes I'm heating the VO to 160*F
so my system is different from one the OP asked about that is unconverted and running some small percentage ( < 25% ) of VO blended with diesel.
However my system is a single tank, and it starts and runs the first 5 miles on cold VO. From 60 to 90% VO concentration. Over 12 years, that's about 25,000 miles of high concentration COLD VO operation. If anything 'bad' was going to happen, it should have happened by now.
Many TDI's have run blends of 25% to 50% w/o reported problems
I've found that only true problem with running high concentration VO is that when temps are <15*F, it doesn't want to pass through the fuel filter till the engine warms up.
Mr. Flibble
Issaquah WA
Interesting. All the guys I know who run WVO/SVO are doing it in Mitsubishi Delicas Both the L400 and L300. With that engine they can't start it if VO has been left in the cylinder after shutdown, and they need to pre-heat it to about 60c before cylinder injection (at 100% VO). I can run 50% or greater VO in my Delica unmodifed, but only in the summer. In the winter, it gels and stops moving. I have never tried more than 50% in my Delica because of issues others I know have had with it in cold climates.
