Softrockrenegade
- Joined
- Aug 25, 2011
- Location
- Howellbama, NJ
- TDI
- None...2011 Golf DSG (replaced by VW W/) 2013 Passat SE 6M(bought back) Current 2017 sportwagen TSI 4Motion.
Here's my hpfp ... My car is a 2011 golf built on 6/10
You need to post images in the thread no larger than 800 pixels. Your giant image is breaking the page format and making everything too wide to read. It is definitely a good thing to have larger image available, but you should set it to open in another window instead of putting it directly in the thread.In the interest of optimism, maybe VW is doing the block of new pumps, because they do have a new pump that doesn't take out whole fuel systems, and as usual, are keeping us in the dark... check out the thread on that Delphi pump for the 1.3TDI and the pictures in the link, where the roller follower is rectangular, not round, and has been around since, oh, 2000, and designed in conjunction with VW... kind of makes you wonder how much Vw saved on that design going with a round follower with Bosch, vs, a rectangular or square roller follower with Delphi? Or maybe it's turning out to be a false savings?
Grab that part number off of that Delphi tag in the photo, and someone needs to make some phone calls or emails.
http://forums.tdiclub.com/showpost.php?p=3565999&postcount=14
http://delphi.com/about/news/media/pressReleases/pr_2010_05_11_001/
Is that Delphi pump compatible or interchangeable with the Bosch pump? Hmmmm? I wonder? Someone with an interest and inside connections should contact Delphi and run with this.
Yeah, environmentalists invented planned obsolesce, consumerism, and rapid product cycles. To think people think concern with the environment is what defines environmentalism. My gasoline car has parts that can't be purchased new anymore. I think Greenpeace and the ACLU have something to do with that.Niner said:In summary, if you have an older car, (4 year old CR TDI for example, with a blown HPFP) and can't get spare parts for it... you can thank an Environmentalist, the same schmucks that brought you the California Air Resources Board, Priuses, and Clean Diesel TDI cars. It looks like VW wants these completely off the road in 600 miles to, oh 5 or 6 years out, at the most.
That's right its environmentalists and socialists fault that its hard to get a new HPFP. Good one. You forgot to blame unions thugs and Obama.A little bit of insight on what it means "going green" with your car... ie, limited parts availability, and socialist governments in Europe going after the parts manufacturers to get the older, dirtier, or more gross polluting cars off the road, by making the parts unavailable and or prohibitively expensive to get ahold of. Then the parts end up being made in third world countries, china, mexico, brazil, etc to get around the regulations.
Anyone with a brazillian head on an older tdi, knows all about the quality control problems.
http://www.autohausaz.com/html/spare-parts-availability.html
Well, if that's how you feel, thanks for adding that.That's right its environmentalists and socialists fault that its hard to get a new HPFP. Good one. You forgot to blame unions thugs and Obama.
This development is good news. I'm not ready to congratulate VW until this becomes a proven design and VW bolts a 4 cylinder variant on my car for at minimum free parts (I'll pay the labor)....
I think VW has something going on, and that they were half a step ahead of NHSTA, that they will only execute their backup plan with the newer designed pump if forced to by NHSTA. I am really quite interested in what engineering over at NHSTA finds, and when they will announce their findings. The new VW/ Delphi designed pump sure looks like VW knew they had a problem on their hands in 2009, when they started work with Delphi on a new pump design......My only concern is how long that black shoe will last in the pressed in steel rectangular bore it runs in with 520 micron fuel. 300, 000 miles? I hope so. Roller failures will be significantly less, that is a given. Aluminum swarf will be less to non existent also.
You're forgetting about "cash for clunkers" and the "clean diesel" tax incentives that prompted many to buy new cars.Most aspects of marketing are very sensitive to timing. Fuel pricing was climbing when VW debuted the new CR's. Most consumers had a clear recollection of the sticker shock at the pump - which we've pretty much adjusted to at this point. If VW didn't push out the CR TDI when they did, they would not have the double digit sales gains they've gotten over the last couple years.
Yep all part of it I guess. The next move is VW's to make as far as I'm concerned.You're forgetting about "cash for clunkers" and the "clean diesel" tax incentives that prompted many to buy new cars.
I think VW has something going on, and that they were half a step ahead of NHSTA, that they will only execute their backup plan with the newer designed pump if forced to by NHSTA. I am really quite interested in what engineering over at NHSTA finds, and when they will announce their findings. The new VW/ Delphi designed pump sure looks like VW knew they had a problem on their hands in 2009, when they started work with Delphi on a new pump design that gets rid of 2 flaws, an aluminum bore with a steel piston running in it, and a cam roller, cam roller shoe, and piston that can get out of alignment with the cam, with attendant failures indicating that it did indeed get 90 degrees out of alignment, and flat spotting the roller by the cam, with attendant shredded aluminum and steel everywhere in the fuel system. The aluminum bore was wearing out, the swarf left in fuel tanks and fuel filters was not being attracted to magnetic forces, so it wasn't iron or steel based swarf.
The new pump design addresses the rotation with the square bore for the follower, and the bore appears to be a steel sleeve pressed in, with a cam follower shoe another black, inert material, in the design. So, no aluminum bore contact, and no out of alignment roller. My only concern is how long that black shoe will last in the pressed in steel rectangular bore it runs in with 520 micron fuel. 300, 000 miles? I hope so. Roller failures will be significantly less, that is a given. Aluminum swarf will be less to non existent also.
A new / different pump is a potential solution that VW could implement for a safety or non-safety issue but doesn't substantiate that there is a safety defect in the current pump. VW has already indicated that revisions to the HPFP make it more robust with respect to poor quality diesel fuel. So, VW could issue a voluntary recall or NHTSA could deem the current HPFP in MY 2009 and 2010 a safety defect and VW then agrees to a recall. But if NHTSA deems the issue to be a safety defect and VW does not agree, the process to ultimately determine whether VW has to correct the defect is a long drawn out process. We could be looking at years.Here is a thought, anyone that has had a failure that has opened a compliant with NHSTA, should get info on the new pump design and send it to NHSTA and just mention the changes between the two. Maybe something will click with some at NHSTA.
I have just spoken to my dealer and he has told me that the pump # 03L-130-851-AX has been cleared for shipment from Germany. I should recieve it later next week. Here we go!
I will be taking the new one apart when I get it to see what the difference is.
Are you sure it is a good idea ?I did give that a tought , but I am planing to sell the car once it is fixed. So I wanted the new owner to have the original pump in their car.
You should ask Bosch Germany what that "X" for a last letter in the part number means.
If you're referring to my post, I was just reposting BrokenTDI's number into that thread for common reference.A guy on this thread also got the same HPFP as BrokenTDI.
http://forums.tdiclub.com/showthread.php?t=284441&page=68
BrokenTDI -I have just spoken to my dealer and he has told me that the pump # 03L-130-851-AX has been cleared for shipment from Germany. I should recieve it later next week. Here we go!
And you forgot to blame G.W. Bush for the whole kit and caboodle, eh? Later!That's right its environmentalists and socialists fault that its hard to get a new HPFP. Good one. You forgot to blame unions thugs and Obama.
