Jamie93
Hi All.
I have a 2014 Golf GTD (184PS EA288 TDI) and have noticed over the last few months a strange knocking noise coming from the engine. The odd thing about this is that the noise only seems noticeable when the engine has not reached full temperature. For example, if the car is started and then driven for about 10 mins (oil temp below approx. 70 degrees C), the noise can be heard quite clearly. If the engine is at full temperature, you cannot hear the noise. Also, if the car is driven and then left for an hour or two to cool down and then started again (not fully cold but cooler), the noise can be heard again?? If the engine is fully cold (after an overnight stand), the noise cant be heard when sat until there is some heat in it. I do, however, sometimes get a very metallic sounding rattle when the car is first started for a second or so which then disappears - could these be connected? I have attached a link to the youtube video which I hope you can hear it from? As the video shows, the noise is not regular in rhythm with the engine?? I hope someone can point me in the direction of what this could be, or give me some advice, as VW aren't sure?
Thank you /
https://www.youtube.com/watch?v=ZT63TE3nnZE
Thank you /
