STDOUBT
'03 Jetta, 134K miles, engine, IP, and drive train are all original, never been R&R'd.
Trying to lock at TDC so I can remove the IP to replace the N108 (Ohms at nothing due to oil/fuel-fouled wiring).
I can see the flywheel mark really well. Cam plate slides in nicely right there, but IP lock hole is off just enough that pin won't enter the hole.
If I remove the cam plate and roll forward a tich, the IP lock pin goes in, but the flywheel mark is then no longer visible, and the cam plate won't go in.
I have the full metalnerd set, with the non-"long-reach" cam plate, so I'm looking at the #1 cam lobes too.
Would I be OK to just lock at flywheel and cam, then try and "reset" the IP lock hole to where it should be once I re-install the IP?
*sigh* I gotta get this car back on the road.
