I'm trying to track down the culprit for these codes that consistently return after I clear them. I've done some research and inspected the CCM already. I see no signs of water damage or corrosion in the plugs, on the pins or on the board itself. When I drive around the block with the VCDS watching 19-CAN Gateway the connections seems to be intermittent at times. Same thing happens when watching the 03-ABS Brakes. I was watching the brakes because occasionally I see a check brake wear message on the dash but no codes in VCDS. Any ideas?
Address 17: Instruments Labels: 3B0-920-xx5-17.lbl
Part No: 3B0 920 929 C
Component: KOMBI+WEGFAHRSP VDO V04
Coding: 15235
Shop #: WSC 00000
VCID: 270BF39CE6FF0B83EE9-513C
WVWPE63BX4P257213 VWZ7Z0D9246189
2 Faults Found:
01330 - Central Control Module for Central Convenience (J393)
49-00 - No Communications
00476 - Control Module for Fuel Pump (J538)
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
Part No: 6N0 909 901
Component: Gateway K<->CAN 0001
Coding: 00006
Shop #: WSC 00028
VCID: 70B9D8C013B10C3B7F3-513C
4 Faults Found:
00463 - Control Module for Digital Sound Package (J525)
01303 - Telephone Transceiver (R36)
Coding: 15235
Shop #: WSC 00000
2 Faults Found:
Coding: 00006
Shop #: WSC 00028
4 Faults Found:
