TDIFLYIN,
I don't believe you have used the search feature at the top of this page (between the new post and quick links up top). You will find that many, MANY people have asked these same questions, so there are a lot of responses to go through.
YOU ASKED:
I would like to run 99% in my car, but the dealer told me it voids my warranty. Why would this be? Also does 99% cause or could it cause damage?
The dealer may have said that using more than B05 will void the warranty on the engine and related stuff, NOT the entire car (that is correct), but it would first be their obligation to prove that the fuel was the problem. If you are using ASTM certified fuel, there shouldn't be a problem. If you are using good stuff 99% should not cause a problem.
AND:Can the dealers pro mechanics tell if I used 99%?
Yes, they can, even just by the smell.
THE 99% I WOULD BE USING IS FROM A TEXACO, NOT HOMEMADE.
Please be as specific as possible with your answers and try and address each question seperately if possible.
THANK YOU so much for your help.
I've been using commercial grade B05, B20, and B100 for 5 years (since 4/02) and have not had a single problem. You have a pumpe duese engine which some feel is more sensitive to fuel quality so I would seek feedback from the users of this pump before going hogwild. Also, remember that even if you use a lighter blend you are STILL using biodiesel so put a sticker on you car showing people that you exist. A lot more people will be driving a diesel in coming years and it is important for them and others to see that we can get OFF of petroleum. Right now we don't have that capacity, so if everyone tanks up with a little it helps a lot until we can provide a higher concentration - by then manufactures will almost certainly up their numbers too. I figure we're early adopters and that true change won't happen for another 5 years or so. But doing your part now will help, even in lower doses.
~BeetleGo
