johnboy00
- Joined
- Jun 15, 2000
- Location
- Bridgewater,Ma.,USA
- TDI
- 2005 Passat Wagon, 2004 Jetta, 2003 Jetta wagon
First the background. My Jetta wagon was T-boned (drivers door) about a year ago in a relatively low speed collision by a Prius. There was enough damage that it would have ben totaled if anyone looked at, but the accident was my fault, and the car was drivable. A friend who's a body guy said he wouldn't touch it, it would take two much time to pull and straighten the b-pillar and bottom rail. I took it too a tree with a come-along ratchet and go it to the point that the doors close and seal and it looks ok from 20ft. I also replaced the front brakes and a wheel bearing around the same time.
Not long after this was done, every now and then, about 2 minutes after I would start driving, the ABS and brake light (dash) would beep and flash for a few seconds, go out, and then never return. This began in Jan or Feb. No codes (I have VCDS) were stored, and brake fluid level was fine.
About a month or two later, my radio (aftermarket Pioneer) would restart and every now and then, do a complete factory reset, as if you disconnected the power. As time went on I noticed that sometimes the radio would reset when I turned the lights on, and occasionally the dash lights would dim for just a second.
These symptoms began to happen more over time to the point where the brake lights flashed 8 out of 10 times in the morning by August. It was becoming clear, or so I thought, that maybe I had some wires got nicked from the accident, or here was a loose ground somewhere. Although I did think that the radio might just be dying.
Towards the end of August, I noticed that my starter was beginning to act up and be slow to start. I tapped on the starter and it got better. Diagnosis: Dust needs a new starter. I have a 99 parts car with a replaced Valeo starter built in 2012. I put that in last weekend.
ALL PROBLEMS WENT AWAY!
How can this be? I only touched the battery terminals, nothing was loose, to my recollection, and if it was, I would think starter problems would be the first to show up. I've been scratching my head for a couple of days now, trying to understand how changing the starter could have fixed what might have been some other electrical problem. Now I'm actually questioning if the other starter was bad, though at 220,000 miles and 19 years, I'm sure it was tired. Luckily I didn't pay for it, and I'm keeping the one I pulled.
Any thoughts? Or anything I should check so my gremlins don't return?
