Cam shaft sensor code, ECM ISSUE???
Hi all,
I have a 2001 VW NB...with a 1.8 turbo engine.
It won't start and throws a code for the Cam Shaft Position Sensor.
I have replaced the sensor, cleared the codes and still no luck.
I get 5 volts from pin #1 to pin #3 as I'm supposed to.
I get 10 volts from pin #2 to engine ground.
When I connect back to the sensor and back probe pin #2 to ground and roll over the engine I get the voltage swing from 0-10 volts as I'm told I should get.
Now when I back probed I actually turned the key to bump the engine over, whereas the book suggests manually turning it over via the crankshaft bolt.
Could I be missing something with the sensor because I didn't do it manually???
Second, the book states that if the voltages are correct at the clip then I should have the ECM checked by the dealer...Could this truly be an issue?? Is there any other way to check the ECM to know for sure??
If I buy a used ECM for this same car and engine size will I need to have it programmed??
If anyone has any answers or suggestions please help.
I'm at my wits end with this car.
Thanks.
Kevin
Hi all,
Thanks.
Kevin
