EvilBunny
- Joined
- Apr 29, 2006
- Location
- konoha village
- TDI
- 85 jetta n/a DEZ(RIP) 03 Golf TDi(RIP), 02 Tdi5spd(RIP), 1984 GLi 20vBT, 85 westy golf(ALH BTswap), 06 M3(RIP), 2013 335is, 2010 690 duke(rip)
this was brought up amonst the MKI guys today. i was like hmm. so i am here asking for someinfo as well. it seems fishy, but i have noo idea!! here is directly from the website.
Its called CA-40 sounds like this does what KY/Astroglide does for all us rabbits, any feed back is welcomeSome info from their site
http://www.ca40g.com/pages.php?pageid=7
How It Works
Calcium is the second best metallic lubricant on the planet, and is used in the best greases. It's also one of the major components of CA-40. The problem has been that no one has ever been able to keep calcium suspended in fuel. Until now.
CA-40 keeps calcium in suspension through our patented blending process. When CA-40 is added to gasoline or diesel, the calcium bonds to hydrocarbons within the fuel, causing it to burn more efficiently. What this means to consumers is increased fuel efficiency, increased lubricity, and a decrease in harmful emissions.
Combustion Enhancement
Unlike other additives, CA-40 is not a solvent. It is actually a combustion enhancer. Usually only about half of the hydrocarbons in fuel are burned in an internal combustion engine. Combustion enhancement is attained through further oxidation of the un-burnt hydrocarbons in the fuel.
There are three things that are needed in combustion: fuel, oxygen and ignition. CA-40 suspends within the hydrocarbons and further allows oxygen and fuel to be held together (fuel and oxygen). The third component of ignition is accomplished due to the thermo-electric and Piezo-electric properties of the calcium in CA-40. When combustion occurs in the engine, the heat and pressure causes the electrons in the calcium to accelerate. This acceleration provides the ignition (spark) in the proximity of the hydrocarbons resulting in further oxidation (burning) of the hydrocarbons. The end result is a longer, stronger push on the piston, causing an increase in horsepower (see Diesel Dyno test page).
CA-40 does not take fuel out of specifications
CA-40 does not change Octane or Cetane, but uses it more efficiently. Independent testing indicated that CA-40 did not take gasoline out of specifications.
Increased Lubricity
As stated above, calcium, a key ingredient in CA-40, is an outstanding lubricant. Tests in gasoline have indicated a 191% increase in lubricity, while ultra-low sulfur diesel tests have shown a 300% increase in lubricity when treated with CA-40 (see Diesel Fuel Lubricity and Gasoline Lubricity test pages).
Environmentally Safe
Catalytic converters burn some of the hydrocarbons not burned in the engine, cleaning vehicle emissions. The problem is, the un-burnt hydrocarbons mean the engine isn't getting as much power out of the fuel as it could, and there are still hydrocarbons that aren't burned. With CA-40, more hydrocarbons are burned in the engine, and the catalytic converter burns all of the remaining hydrocarbons. Vehicles tested using fuel treated with CA-40 had ZERO un-burnt hydrocarbons at the tailpipe. Engines burning fuel treated with CA-40 have tested with a 50% reduction in Nitrogen Oxides (See Emissions test information page). Also, all ingredients in CA-40 are environmentally friendly.
CA-40 is backed by a $2 million insurance policy
How It Works
Increased Lubricity
