BV43A install in my 2005 B5.5 BHW
CarlosVW
Mayfield, Kentucky, USA
05 VW Passat 2.0L TDI /BHW engine code/ BSM deleted/ Malone Stage 2 Custom/ Stage 2 Colt Cam/ BV43A turbo upgrade/ Bosio 1043 Injector Nozzles
You really should read my build thread. Ebay is full of reinforced silicone reducing 90's, etc to make your install clean. Use t band clamps too. Regular hose clamps won't hold 2 bar of pressure.
I keep blowing my lower elbow out.
Sent from my iPad using Tapatalk
50harleyrider
charleston,wv
2005 B5.5 TDI/geared BSM, BV43A turbo,stage 2 TDTUNING. 2005 5sp manual passat tdi stage 2 tdtuning,BSM delete. 2015 Passat TDI 6sp manual.
Those elbows are available in multi ply. You shouldn't be blowing them out unless you have other issues. Actually failing or coming loose? How much are you boosting?
CarlosVW
Boosting 28-30#. They’re splitting up.
50harleyrider
charleston,wv
I can trade you a stock turbo. PM me
tims944
montreal quebec
2015 Golf Sportwagen TDI, 2006 mk5 tdi-SOLD 1989 944 s2 BHW swapped
hi guys so i did a lot of readint through this thread.
i found this BV43 turbo stock brand new from germany.
im running a FMIC so the plumbing on the 43 is fine dont need the 43a outlet.
anyone run one of these, i dont need 240hp, so frans or xman turbos are a little pricy this is much cheaper?
thoughts?
it will be for a 6 speed RWD BHW project :D
https://www.ebay.com/itm/Turbolader...654985&hash=item41e79fa64f:g:f1QAAOSw9mpZ5iFW
also please dont buy it out from under me haha...
waiting for comments before buying.
thanks tim
G60ING
Annapolis, MD
It’s worth it, it’s a more robust turbo than stock and has great potential,
tims944
montreal quebec
did you install the stock compressor with basic compressor wheel or did you have one of the known shops swap in different wheels?
thanks im working on finding the exact one i want and just ordering it,
G60ING
Annapolis, MD
Paul Neese
Alexandria, IN
2000 NB
I was looking into running a GT2052. Anyone have any idea about how it compares as far as boost potential and ease of installation? Any thoughts as compared to the BV43A? It’d be going on a B5.5 that has tons of mods including the 5 speed tdi swap. Already has a TDTuning tune and ate the stock VNT17 in 30k miles.
vwztips
Greenville, SC
2005 Passat GLS Wagon TDI 5 spd manual w/BSM delete 2012 Tiguan TDI/DSG 2005 Audi A4 6MQ 2011 BMW X5 35d
FWIW, the TDTune did not eat your VNT17. Have many swapped cars out there running that tune with no issues with the turbo.
Doobie666
Remington,VA
2004 Passat Wagon
Finally found this! Posting so I have it.. will have to reach out to Fran’s and see what options he has available.. I have Malone stage 2 with frank 06 cam egr delete.. this is exciting 🤤
50harleyrider
charleston,wv
You'll like it. Very simple conversion as you can see in my thread. I'm planning to transplant my BV43 stage 2 BHW into an 03 Explorer Sport Trac 4x4.
Doobie666
Remington,VA
2004 Passat Wagon
Nice I’m going to read up on that thread to.. iv been looking into a gt17vb which I believe is very similar but no need for custom fab piping.. not sure going to have to look more into this
50harleyrider
charleston,wv
gt17vb might be good especially if it has the spring locks so you can use the oe passat boost plumbing.
