Buying Used Turbo
outoforder
Dover, OH
2003 Jetta
My current turbo has 310,000 miles on it and it starting to leak some oil. I am considering replacing it but am currently in a money crunch. I can buy a used Garett turbo with 196,000 miles on it and save several hundred dollars. Thoughts?
Windex
Cambridge
05 B5V 01E FRF
Are you a gambling man?
Vetting a used turbo is a gamble for even a skilled individual who is used to checking impeller play and VNT vane operation.
You want zero axial (thrust) play, and very slight to no radial play.
outoforder
Dover, OH
2003 Jetta
I am anything but, however a slight bout of desperation has me considering it. My other option is to select from two turbos on rockauto
Rotomaster: $484
MAHLE: $694
With the rotomaster being significantly less, I feel like its quality is in question.
mjydrafter
dsm, ia
2004 Jetta Wagon
There is a recent thread (either here or in the 101 section) that mentions a Rotomaster from Rock auto. The results were not good. Here.
It could be a fluke, but I would consider it.
I would save for a new Garrett, or stock BW. The Garret requires a few extras, but it seems to be the gold standard in replacement turbo's.
The used Garrett would be a gamble (like Windex says), especially with it's mileage.
Turbodude1
Auburn Maine
1999.5 Golf 2dr. RCII, sprint 520s, shine susp
ID Parts has reported good success with the Mahle unit. I might be inclined to give that a shot.
Rembrant
Canada's Ocean Playground
2013 Golf TDI DSG
I bought a new Mahle VNT15 last year for my Golf. It now has about 70,000 kms on it, or 44k miles and it is working like new. No problems yet.
I bought a used Garret VNT15 with unknown mileage for my Beetle. I wasn't spending money on a new turbo at the time as I wasn't sure if the car was worth keeping. Turns out the car is fine, and I've put almost 11,000 kms on it in the past 6 weeks (or 6500 miles). Although the turbo was used, the rotating element was fine. I backflushed oil through the CHRA a couple nights in a row, and installed a new actuator.
My original plan was to install a new Mahle VNT15 later, but the used Garrett is working well enough I'm going to leave it for now and just keep my eye on it.
I think buying a used turbo is OK...as along as you know what to look for in a used turbo, annnd you are OK with the risk.
flee
Chatsworth, CA
2002 Jetta GLS wagon
I got lucky buying a used VNT-15 from a TDIClub member, mileage unknown.
(Thanks, Kree, still going strong!)
I have a new Mahle on the shelf and I will swap it out at the first sign of trouble.
PakProtector
AnnArbor, MI
Mk.4's and the Cummins
Still running a used HX35 I got for my '90 Cummins. Shaft bearings were fine when I got it, and are still fine...:) They are rebuildable, and do *NOT* have that pesky VNT dealie. When my TDi needed one, I sprung for a VNT17 when IDParts put them on sale earlier this year. Getting the turbo on and off was a PitA, and well worth a few hundred in order to avoid the gamble.
cheers,
Douglas
Vindiesel6
Northern, NJ
2015 Q5 TDI
I have a used vnt15 turbo in perfect operating condition which only needs one stud extracted from the exhaust downpipe end. I didn't have time to play with extracting the stud and just got a new one. I'd be willing to let it go for a great deal. Search for my FS thread if interested or pm me.
mslaptoptx
Austin, TX - Brushy Creek
03 Jetta ALH, 01 ALH Golf 2 Door
I've got a stock VNT-15 with about 70K on it. It was changed under warranty at 90k , the car now has 162k on it. I upgraded to a VNT-17. It's yours for $300 plus shipping. All there everything works.
