runonbeer
Maintenance EnthusiastVendor
Yo,
I've got a 93 GMC 3500HD with a 6.5 turbo D engine. We had the truck donated to us (austinbiofuels) with two cracked heads and a blocked radiator. We replaced the radiator and put a long block in it. THE DAY we got it running it had an intermittent popping sound coming from the right cylinder bank. The sound is RPM dependant and an increase in smoke is observed when the sound is heard. I thought it was the vacuum pump so I just ignored it. One day I got sick of it so I took the vacuum pump off (it was for trailer brakes) Still popping. Decided it was an exhaust leak. come to find out it is actually sticking intake valve. This was verified by removing the upper intake manifold and jamming a gloved hand into the #2 port; effectively eliminating the noise (which is significantly more pronounced with the upper intake removed). Compression test showed good compression but again, it is an intermittent problem.
So it was concluded that we were experiencing a sticking hydraulic lifter.
The cylinder head was removed and 2 pushrods and 2 lifters were replaced (lifters were $48 bucks a pop, no pun intended).
Problem persists, though not as regular or for as long a duration per event. It will pop for anywhere between 25 seconds and 1 minute usually following high speeds (>65mph) but sometimes for 10-12 seconds upon start up.
We've got good oil pressure, no overheating isuues, no excessive wear in the valve train of the right bank.
The sound is very embarassing especially at stop lights with our "Powered by Biodiesel" stickers all over the truck (the problem is not related to the fuel). The warranty on the engine expired the day after we got the head back on. and the engine supplier (South Houston Engine) has told us that they are shipping the lifters to their lifter supplier, but we have not heard from them in 1.5 months or so.
We affectionately call the truck "Bup Bup"
Have you guys got any ideas?
-rob
-rob
