cuban11182
So a buddy of mine ingested some carbon, and bent a valve. He took it to a machine shop and they verified the valve, and checked out the rest of the head, and it's all good.
So with the head off, we need to time the crank, injection pump, and cam. I know with the cam, we have to have number 1 valves pointed up and lock the cam. With the injection pump, all we have to do is lock it with the tool. His flywheel has no marks on it, so I'm not sure what to do with that. I have two questions:
1. With the injection pump, as long as I lock it into the right hole as when I'm doing the timing belt, I should be good? Can the pump be 180 degrees out, or does that alignment pin link up to where it needs to be, and should be good.
2. With the crank, and not having the mark on the flywheel, can it be 180 degrees out? How do I know if I'm on the intake or exhaust stroke when the piston is up on top, or does it not matter either way since I'll be timing the cam and injection pump when number 1 is up top (regardless of whether or not it was previously intake or exhaust).
Thanks in advance.
Thanks in advance.
