It's always the same question. It is just a TB or what else is wrong? It's best to give yourself a margin of error in case something else is broken or worn out and not mentioned.
Oftentimes, cam, lifters, guides and a few valves and you are good to go. However, there are enough instances that a highway-speed timing belt break will damage rods and pistons. Always check piston projection. If the pistons are within .004" of each other, you can probably put it together and it's ok. Of course, you can't know about injectors, clutch, or auto; things like that unless it runs.
If the owner will allow you to remove the cam, the picture will be much more clear. The more shattered the lifters, the more you'll be paying to repair.
Good luck.
Anything from a bad crank, bent rods, clutch or flywheel... My best advice is buy it as it you are going to scrap it. Then you won't be hurt if something turns up that is a major fault.
