nh mike
I discovered today that my right rear spring snapped, at the base - interestingly it is still attached to .... whatever that cup-like thing is the spring "sits" in - not enough of it snapped for it to become fully disconnected - although it does make a worrisome noise when going over a bump (sort of a cross between "sproing" and "clunk").
This seems like awfully early for a spring to break, doesn't it? Of course, a road I drive on every day is plain awful (rated a 5 out of 100 by the city engineer last year - and it got far, far worse this winter), with massive craters all across the road, that go down to the bare dirt underneath the asphalt.
Anyway - how hard/easy is it to replace springs? Is it a fairly straightforward DIY job? (jack up car, take off wheel, somehow detach old spring, and put in new spring) Or is there some weird special tool one needs to get the springs in there?
I tried searching for threads on broken springs, and replacing springs, but apparently many parts of our cars have springs (fuel sender check valve, a little spring in the injection pump, etc.), so most of the threads I found didn't actually have anything to do with the suspension springs....
Thanks.
Thanks.
