sayers
I changed my timing belt over the thankgiving holidays. This is my second tb change. I decided to inspect the camshaft for wear before I started. I pulled the rockers and went through with the inspeciton and was about to put the valve cover back on when I discovered that the ball pin on the injector closests to the timing belt was cracked.
When I removed the pin it fell apart. Anybody ever seen this happen?
I was able to find another pin locally along with a used adjuster pin.
My worry is that this is a symptom of something wrong with that injector. The camshaft shows hardly any wear that I can tell. the mileage is 160k.
see pics below.
see pics below.
