RayBrubaker
I loaned my '96 B4 wagon to a good friend and coworker to use while back from work overseas. While traveling in Nebraska it started to loose power on hills, run a bit rough, and set a code. AutoZone read the code as P1248. I made some suggestions of what to check and due. He cleaned the MAF and took it for a test drive, this is what he wrote: "It seemed like is was running smoother but if I had the throttle wide open it would accelerate well up to about 3800 rpm and top out. If I reduced the throttle position about 3/4 open or so then the car would accelerate to a higher rpm. I turned around and heading home the engine quit very smoothly. Not sure of the problem I checked for blown fuses. I can't start it now but the fuel lines all look full with no bubbles." He checked the timing belt, it is fine. On a recommendation from a friend at church he took it to "Precision Import Repair" in Kearney about six days ago, they have not been able to work on it yet.
Any suggestions of what might be the problem? He failed to check the fuel filter but that shouldn't cause a sudden shutdown. I fear an injector pump failure although I inspected the pump interior not long before loaning the car and it was clean without any evidence of making metal. Is an ECM failure likely?
Is the shop mentioned a good choice for the area?
I am overseas myself right now so handling this by email as I can.
Thanks for any help,
Ray
Ray
