turbocharged798
Looking at my Bentley and confirmed in real life, the 09G auto transmission that came with the 5 cylinder gasser MK5s has the perfect ratios for TDIs. Does any one know if it would work with a BRM? I know that it should bolt up as the bell housing is the same for 5 cylinder and TDI. Question is if the electronics would play nice and if the TCU can be retuned for TDI shift points.
If you have to ask why, its because 5-cyl MK5s are cheap and plentful and would make swapping a PD100 into them a piece of cake.
Thanks!
Thanks!
